Home » Eclipse Projects » BIRT » How to save old BIRT rptdesign in newer version?
How to save old BIRT rptdesign in newer version? [message #893905] Thu, 05 July 2012 18:13 Go to next message
R J is currently offline R J
I have upgraded Eclipse to Indigo (3.7.2). Used eclipse-reporting-indigo-SR2-win32-x86_64. Every time I modify the rptDesign file it prompts with a message - "The report was created with earlier...." Please see the attachment for the complete text. I don't want to upgrade, for business reasons want to continue with the previous version of rptdesign file. How do I do it?
index.php/fa/10592/0/
Thank you.
RJ
  • Attachment: Message.JPG
    (Size: 19.52KB, Downloaded 225 times)
Re: How to save old BIRT rptdesign in newer version? [message #894028 is a reply to message #893905] Fri, 06 July 2012 08:40 Go to previous messageGo to next message
Missing name Missing name is currently offline Missing name Missing name
Member
You could download the standalone BIRT RCP designer corresponding to the version that the reports were written in and then maintain them in that, outside of eclipse itself?
Re: How to save old BIRT rptdesign in newer version? [message #894071 is a reply to message #893905] Fri, 06 July 2012 10:28 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
BIRT does not have this feature. If you are not using any specific
features of the newer version you could try to replace the version lines
in the xml with the older version.
Jason
On 7/5/2012 6:13 PM, R J wrote:
> Thank you.
> RJ
Jason Weathersby
BIRT Exchange
Previous Topic:Values in a chart are not in sorting order
Next Topic:SEVERE: An exception occurred during processing.../SELECT command denied to user...
Current Time: Tue May 21 10:51:57 EDT 2013
Powered by FUDForum. Page generated in 0.01702 seconds
