Home » Newcomers » Newcomers » Troubleshooting Eclipse 4.2 Performance - How?
Troubleshooting Eclipse 4.2 Performance - How? [message #893849] Thu, 05 July 2012 12:56 Go to next message
Missing name Missing name is currently offline Missing name Missing name
After installing Eclipse 4.2 with PDT and SVN on Windows 7 I get terrible performance opening, closing and switching between PHP files.
How should I go about troubleshooting what the problem might be? What information do I need to collect if I were to ask for help with this issue?
TIA
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #895268 is a reply to message #893849] Thu, 12 July 2012 06:20 Go to previous messageGo to next message
Sergei Stolyarov is currently offline Sergei Stolyarov
I'm using linux x64 version and tabs switching is painfully slow. So I've took some steps to investigate and found A LOT of errors occur when I switch from one PDT tab to another:
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.wst.server.ui.internal.webbrowser.actionSet
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #895272 is a reply to message #895268] Thu, 12 July 2012 06:32 Go to previous messageGo to next message
Here is the example of such exception gist.github.com/3097283
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #895335 is a reply to message #895272] Thu, 12 July 2012 09:37 Go to previous messageGo to next message
Toshihiro Izumi is currently offline Toshihiro Izumi
There is a PDT forum.
As for the problem, try installing "Eclipse Web Developer Tools" from Juno update site.
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #895583 is a reply to message #895335] Fri, 13 July 2012 12:53 Go to previous messageGo to next message
Yeah, I don't think this is a PDT issue. I think this has to do with tabs switching on the 64 bit platform.
It's just painfully slow. I'm just a user here, without enough knowledge of the internals to fix it myself. I'm just doing my best to report the issue so it can be addressed.
If there's more I could do to gather the necessary information please let me know.
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #901340 is a reply to message #895583] Fri, 10 August 2012 19:01 Go to previous messageGo to next message
sielver Missing name is currently offline sielver Missing name
Member
Try switching to a different perspective (from PHP), then restart Eclipse.
Better now?
(http://crossplatform.net/dev/eclipse-juno-pdt-and-slow-tab-switching.html, I'm "Jeto" there btw)
[Updated on: Fri, 10 August 2012 19:02]
Report message to a moderator
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #901341 is a reply to message #901340] Fri, 10 August 2012 19:32 Go to previous messageGo to next message
No, it appears to be just as slow an any other perspective.
I can tell you this... Indigo flies. Juno is slow as molasses.
I tried Juno win 32... slow.
I tried Juno win 64... slow.
I went back to Indigo and it works wonderfully.
I don't know what else to test, but the performance of the Juno UI is terribly slow on my Windows 7 machine. The most obvious symptom is the near 5 - 6 second wait switching between tabs.
My machine is a fairly new install, no viruses, no misconfigurations, latest version of Java SDKs. So what else is there to test?
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #901343 is a reply to message #901341] Fri, 10 August 2012 21:16 Go to previous messageGo to next message
Eclipse Community Forums: Eclipse 4 ยป Eclipse 4.2 GUI is very slow
Re: Troubleshooting Eclipse 4.2 Performance - How? [message #901352 is a reply to message #901341] Sat, 11 August 2012 04:01 Go to previous message
Member
Missing name Mising name wrote on Fri, 10 August 2012 19:32
Well it's weird because the PHP perspective is the reason the UI is slow on like 10 machines I've tested it. Under the Resource perspective, for instance, it's almost as fast as Indigo was.
Did you restart Eclipse *after* switching to the other perspective? (Try the Resource one)
Previous Topic:How do I change XML files programmatically?
Next Topic:No "R.xxx" file generated for me.....
Current Time: Sun May 19 03:12:49 EDT 2013
Powered by FUDForum. Page generated in 0.02878 seconds
