Home » Language IDEs » PDT » SQL syntax highlighting and code completion in Eclipse PDT(Is this possible?)
SQL syntax highlighting and code completion in Eclipse PDT [message #893775] Thu, 05 July 2012 09:43 Go to next message
Oleg Prizov is currently offline Oleg Prizov
Is there a way of enabling highlighting (and/or code completion for SQL) for SQL syntax in PHP strings variable while developing some PHP works related to SQL using Eclipse PDT?
The question is more general really, not only for the PDT, but for the other languages too. The main idea - is there a way to enable highlighting/code-completion for strings in one language, while developing in other language?
Re: SQL syntax highlighting and code completion in Eclipse PDT [message #899803 is a reply to message #893775] Thu, 02 August 2012 08:01 Go to previous message
chen thierry is currently offline chen thierry
Im afraid the answer is NO.
If you have real complex and long SQL queries, you may debug syntax in a separate sql editor
Previous Topic:Word Wrapper Desperately Needed
Next Topic:Eclipse hangs when editing PHP files
Current Time: Thu May 23 11:38:52 EDT 2013
Powered by FUDForum. Page generated in 0.09241 seconds
