Home » Newcomers » Newcomers » Unable to get SVN from update site
Unable to get SVN from update site [message #893591] Wed, 04 July 2012 14:03 Go to next message
Jay Gorrell is currently offline Jay Gorrell
I'm trying to get the subversive from the Juno update site. When I do this, it hangs. I forgot about it for 3 or 4 days and it was still hung. I select the check box to not check all update sites, and I get passed that part. Then it hangs while installing. It never gets passed 0%.
Any ideas on how I can fix this. I tried installing them manually be placing them in the dropins folder, but then Eclipse wasn't able to install the connectors. It just kept getting an error saying it couldn't install.
This is a fresh install of 64 bit Eclipse on windows. I'm running 64 bit Java 6_26.
Re: Unable to get SVN from update site [message #893618 is a reply to message #893591] Wed, 04 July 2012 19:14 Go to previous message
I was able to download the entire site for SVN so I installed it locally but it still didn't work. I tried it on the 32 bit version of eclipse, but no more luck. Here is the errors from the error log:
Error
Wed Jul 04 17:31:42 CDT 2012
Provisioning exception
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/mylyn/releases/juno/compositeContent.jar.
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:371)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:208)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:73)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:98)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:758)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:117)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:102)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:83)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.io.IOException: Not in GZIP format
at java.util.zip.GZIPInputStream.readHeader(Unknown Source)
at java.util.zip.GZIPInputStream.<init>(Unknown Source)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer$GzipGetMethod.getResponseBodyAsUnzippedStream(HttpClientRetrieveFileTransfer.java:144)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:723)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:879)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:570)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:422)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:355)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:156)
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:345)
... 13 more
Error
Warning
Server returned lastModified <= 0 for http://download.eclipse.org/mylyn/releases/juno/compositeContent.jar
Previous Topic:Eclipse BIRT Report Performance Issues
Next Topic:Install Multiple Eclipse Plug-ins via update site
Current Time: Fri May 24 12:04:26 EDT 2013
Powered by FUDForum. Page generated in 0.02541 seconds
