Home » Modeling » Model-to-Model Transformation » M2M for genmodel
M2M for genmodel [message #893514] Wed, 04 July 2012 08:14 Go to next message
Matthias N is currently offline Matthias N
Member
I have generated my genmodel out of the Ecore.
The attribute "Label Feature" is set to "name:EString" by default.
But I want it to be another attribute, e.g. "shortName:EString". This would simply imply: change from "name:EString" to "shortName:EString"
Is there a way to do it for all elements using a script ? I don't want to set it by hand because the genmodel has several hundred elements.
Re: M2M for genmodel [message #893519 is a reply to message #893514] Wed, 04 July 2012 08:31 Go to previous messageGo to next message
A genmodel is a model so of course an M2M is possible.
The change is very regular, so I suspect that a simple text editor
search and replace might work.
But, the genmodel derives the label feature automatically. You might be
able to adjust your Ecore model so that genmodel is correct in the first
place.
Ed Willink
On 04/07/2012 13:14, Matthias N wrote:
> Thanks
Re: M2M for genmodel [message #894485 is a reply to message #893519] Mon, 09 July 2012 07:59 Go to previous messageGo to next message
Member
Ed Willink wrote on Wed, 04 July 2012 08:31
place.
Ed Willink
> Thanks
I really need to change the genmodel. Text search & replace won't work either.
Which technology would you recommend for the M2M transformation ?
Re: M2M for genmodel [message #894489 is a reply to message #894485] Mon, 09 July 2012 08:22 Go to previous message
The MMT home page
http://www.eclipse.org/projects/project.php?id=modeling.mmt lists
available Eclipse M2M tools.
Since your change is very small you want something that facilitates a
copy by default; I think ATL may have this.
Ed Willink
>> Hi
>> be able to adjust your Ecore model so that genmodel is correct in the
>> first place.
>> Regards
>> Ed Willink
>> > Hi,
>> This > would simply imply: change from "name:EString" to
>> "shortName:EString"
>> want > to set it by hand because the genmodel has several hundred
>> elements.
>> > Thanks
> either.
Previous Topic:Apply a profile to UML model
Next Topic:[ATL] Unresolved cross-reference... Again
Current Time: Thu May 23 11:31:13 EDT 2013
Powered by FUDForum. Page generated in 0.03231 seconds
