| unable to start jboss server eclipsce in debug mode [message #893420] |
Wed, 04 July 2012 00:40 |
reshma bhasuri Messages: 2 Registered: July 2012 |
Junior Member |
Hi all!
I am unable to start jboss server in debug mode. when i am trying to start jboss server in debug mode it is showing
Exception in thread "main" javax.naming.CommunicationException: Could not obtain connection to any of these urls: localhost:1099 [Root exception is javax.naming.CommunicationException: Failed to connect to server localhost:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server localhost:1099 [Root exception is java.net.ConnectException: Connection refused: connect]]]
at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1562)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:634)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:627)
at javax.naming.InitialContext.lookup(InitialContext.java:392)
at org.jboss.Shutdown.main(Shutdown.java:214)
Caused by: javax.naming.CommunicationException: Failed to connect to server localhost:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server localhost:1099 [Root exception is java.net.ConnectException: Connection refused: connect]]
at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:274)
at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1533)
... 4 more
Caused by: javax.naming.ServiceUnavailableException: Failed to connect to server localhost:1099 [Root exception is java.net.ConnectException: Connection refused: connect]
at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:248)
... 5 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:519)
at java.net.Socket.connect(Socket.java:469)
at java.net.Socket.<init>(Socket.java:366)
at java.net.Socket.<init>(Socket.java:267)
at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:84)
at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:77)
at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:244)
... 5 more
any ideas about this.??? it is also popping up a window as "An internal error has occurred.
java.lang.NullPointerException ". can anyone help me on this.
FUDForum. Page generated in 0.01538 seconds
