Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Nested scrollable items?(Both parent control and List item are scrollable, but only parent control allows scrolling)
Nested scrollable items? [message #893262] Tue, 03 July 2012 07:54 Go to next message
Jasper Spaans is currently offline Jasper Spaans
I'm creating a plugin for eclipse, and using a Property page for some of it's settings.
The problem I'm faced with is that the property page contains (a couple of) lists that I want to have scrollable, but I can't seem to make that work.
Instead, (one of) the surrounding parent composit's is made scrollable.
I'm posting the parts of my program that I think are relevant here:
import org.eclipse.jface.preference.ColorFieldEditor;
import org.eclipse.jface.preference.IPreferenceStore;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Canvas;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.List;
import org.eclipse.swt.widgets.TabFolder;
import org.eclipse.swt.widgets.TabItem;
import org.eclipse.swt.widgets.Text;
import org.eclipse.ui.IWorkbenchPropertyPage;
public class ContentPropertyPage extends org.eclipse.ui.dialogs.PropertyPage implements IWorkbenchPropertyPage {
	private String[] lstDataNames;
	private List dataNamesObject;
	private ColorFieldEditor dataNamesColorObject;
	protected Control createContents(Composite parent) {
			  Composite myComposite = new Composite(parent, SWT.BORDER);
              myComposite.setLayout(new FillLayout());
              TabFolder maintabs = new TabFolder(myComposite,SWT.BORDER);
              Composite lst = makeTab(maintabs,"LST");
              lst.setLayout(new FillLayout());
              TabFolder subtabs = new TabFolder(lst,SWT.BORDER);
              lstDataNames = convert(getProperty(LST_DATANAMES));
              Composite comp = addTab(subtabs,"Data Names");
              dataNamesObject = addList(comp,lstDataNames);
              dataNamesColorObject = createPane(comp,LST_DATANAMES_COLOR,dataNamesObject);
              return myComposite;
private List addList(Composite comp,String[] items){
		List lstList = new List(comp,SWT.V_SCROLL);
		lstList.setItems(items);
		return lstList;
	private Composite addTab(TabFolder tabs, String tabName){
		Composite comp = makeTab(tabs,tabName);
		comp.setLayout(new GridLayout());
		return comp;
	private Composite makeTab(TabFolder tabs,String tabName){
		TabItem tabItem = new TabItem(tabs, SWT.BORDER);
        tabItem.setText(tabName);
		Composite comp = new Composite(tabs,SWT.BORDER);
        tabItem.setControl(comp);
        return comp;
	private ColorFieldEditor createPane(Composite shell,String color,final List list){
		GridLayout layout = new GridLayout(4, false);
		shell.setLayout(layout);
		list.setLayoutData(new GridData(SWT.LEFT, SWT.FILL, false, false, 1, 5));
		Canvas can = new Canvas(shell,SWT.NONE);
		ColorFieldEditor colorEditor = new ColorFieldEditor(color,"Highlight Color",can);
		can.setLayoutData(new GridData(SWT.FILL,SWT.TOP,false,false,3,1));
		final Text newEntryText = new Text(shell, SWT.NONE);
		newEntryText.setLayoutData(new GridData(SWT.FILL,SWT.TOP,true,false,2,1));
		Button b = new Button(shell, SWT.PUSH);
		b.setText("Add to List");
		b.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent event) {
				list.add(newEntryText.getText(), list.getItemCount());
		b.setLayoutData(new GridData(SWT.LEFT, SWT.TOP, false, false, 1, 1));
		b = new Button(shell, SWT.PUSH );
		b.setText("Remove Selection"); //$NON-NLS-1$
					if(list.getSelectionIndex()>0){
				list.remove(list.getSelectionIndex());
		b.setLayoutData(new GridData(SWT.LEFT, SWT.TOP, true, false, 1, 1));
		Label la = new Label(shell,SWT.NONE);
		la.setLayoutData(new GridData(SWT.FILL,SWT.FILL,true,true,2,1));
		la.setLayoutData(new GridData(SWT.FILL,SWT.FILL,true,true,3,2));
		la.setLayoutData(new GridData(SWT.LEFT,SWT.FILL,true,true,1,1));
		b.setText("Export List");
		b.setLayoutData(new GridData(SWT.LEFT, SWT.BOTTOM, false, false, 1, 1));
		b.setText("Import List");
		return colorEditor;
Can anyone tell me what I'm doing wrong?
(also, if this is the wrong place to ask this, or you need more info, please tell me where to go/what to add)
edit: also providing screenshot of how it currently looks. Instead of the scrollbar on the right, the list should be shorter and have a scrollbar
[Updated on: Tue, 03 July 2012 07:58]
Report message to a moderator
Re: Nested scrollable items? [message #893282 is a reply to message #893262] Tue, 03 July 2012 09:02 Go to previous messageGo to next message
Jan Krakora is currently offline Jan Krakora
Hi Jasper,
to make your list scrollable you have to tell the parent layout how tall they preferably should be. Because by default it will try to set theirs size to theirs preferred size.
    List lstList = new List(comp, SWT.V_SCROLL);
    lstList.setLayoutData(GridDataFactory.fillDefault().hint(SWT.DEFAULT, 80).create());
    return lstList;
Re: Nested scrollable items? [message #893287 is a reply to message #893282] Tue, 03 July 2012 09:12 Go to previous messageGo to next message
Thanks!
Unfortunately, that does not fix my problem.
Re: Nested scrollable items? [message #893298 is a reply to message #893287] Tue, 03 July 2012 09:36 Go to previous messageGo to next message
Well, maybe it's because you set the layout data in the createPane() again. Try to set height hint there and not in the addList().
[Updated on: Tue, 03 July 2012 09:44]
Re: Nested scrollable items? [message #893311 is a reply to message #893298] Tue, 03 July 2012 10:05 Go to previous messageGo to next message
Yes! that's it....
I eventually changed it to:
GridData listGridData = new GridData(SWT.LEFT, SWT.FILL, false, false, 1, 5);
		listGridData.heightHint = 300;
		list.setLayoutData(listGridData);
But that seems to do the trick.
I cannot believe how long it took me just to get myself to ask this here, and then to get the answer within the hour....
Re: Nested scrollable items? [message #893318 is a reply to message #893311] Tue, 03 July 2012 10:14 Go to previous message
Yeah, this forum is great if there is somebody who can give you the answer Smile
Previous Topic:autocomplete in ComboViewer
Next Topic:SWT OLE Excel windows
Current Time: Sat May 25 22:56:22 EDT 2013
Powered by FUDForum. Page generated in 0.01744 seconds
