Home » Eclipse Projects » Jubula » Integrate Jubula with Jenkins(Integrate Jubula with Jenkins for a test of an Eclipse plugin)
Integrate Jubula with Jenkins [message #892540] Thu, 28 June 2012 10:54 Go to next message
Zhongling HANG is currently offline Zhongling HANG
Now I need to integrate Jubula with Jenkins and execute a test for an Eclipse plugin. I have followed the step as the example "Automating Eclipse Jubula Tests with Jenkins" in the Internet.
I created a new job and added three script shells:
(1) rm -rf $WORKSPACE/testresults/*; mkdir -p $WORKSPACE/testdata; mkdir -p $WORKSPACE/testresults
(2) D:/jubula/server/autagent -p 60000 -v
(3) D:/jubula/jubula/testexec -project My Third Project -testsuite test2 -server localhost -port 60000 -autconfig Eclipse3 datadir $WORKSPACE/testdata -data /home/jenkins/.jubula/workspace -resultdir $WORKSPACE/testresults -version 1.0 -language en_US -dbscheme "Default Embedded (H2)" -dbuser sa -dbpw ""
But I lance the job and there is a mistake:
Building in workspace D:\Utilisateurs\A534346\.jenkins\jobs\Plugin Test\workspace
[workspace] $ sh -xe C:\Windows\TEMP\hudson9006745285536089314.sh
The system cannot find the file specified
FATAL: L'exécution de la commande a échoué.
java.io.IOException: Cannot run program "sh" (in directory "D:\Utilisateurs\A534346\.jenkins\jobs\Plugin Test\workspace"): CreateProcess error=2, Le fichier spécifié est introuvable
I have installed Jubula in the disk D and my system is Windows 7. For "/home/jenkins/.jubula/workspace", I don't know how to change the configuration. And for the mistake of the test, is it because I just missed some steps? Thank you for your response.
Jubula, SWTBot
[Updated on: Thu, 28 June 2012 10:55]
Report message to a moderator
Re: Integrate Jubula with Jenkins [message #892625 is a reply to message #892540] Thu, 28 June 2012 15:12 Go to previous messageGo to next message
Achim Loerke is currently offline Achim Loerke
I think something is mixed up in your Jenkins setup. The job tries to execute a Unix shell script (using sh -xe) on a MS Windows system. This is unlikely to work.
Even if it would work your path names for the autagent and testexec contain / characters which will probably yield syntax error in cmd files.
- Achim
Re: Integrate Jubula with Jenkins [message #892962 is a reply to message #892625] Mon, 02 July 2012 03:48 Go to previous messageGo to next message
Thank you very much for your explanation. I just want to integrate Jubula with Jenkins and execute a test for an Eclipse plugin on a Windows System. I have not found a good example. Do you have an idea about how to do it and can you help with that?
Jubula, SWTBot
[Updated on: Mon, 02 July 2012 03:52]
Re: Integrate Jubula with Jenkins [message #893257 is a reply to message #892962] Tue, 03 July 2012 07:32 Go to previous message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
If the blog entry and Achim's hints aren't enough, then you might want to wait and see if any other community members can help you, or have a look at the "Professional Support" section on the Jubula pages.
Alex
Previous Topic:Regular expression is failing in latest Jubula
Next Topic:AssertException
Current Time: Fri May 24 06:27:25 EDT 2013
Powered by FUDForum. Page generated in 0.05721 seconds
