Home » Eclipse Projects » BIRT » BIRT support for PDF and Excel report Generation
BIRT support for PDF and Excel report Generation [message #892160] Wed, 27 June 2012 05:24 Go to next message
Sneha Patil is currently offline Sneha Patil
Which technology/software BIRT uses internally for generation of pdf or excel reports? Can we add support for Adobe Lifecycle??
Re: BIRT support for PDF and Excel report Generation [message #892526 is a reply to message #892160] Thu, 28 June 2012 10:25 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
For PDF BIRT uses iText, the xls emitter uses internal code. There are
other xls emitters in the community that use POI.
Jason
Jason Weathersby
BIRT Exchange
Re: BIRT support for PDF and Excel report Generation [message #892672 is a reply to message #892526] Fri, 29 June 2012 02:35 Go to previous messageGo to next message
Thanks for this helpful information. I also want to know if we can add support for Adobe Livecycle or any other open source for pdf or excel generation?
Re: BIRT support for PDF and Excel report Generation [message #892802 is a reply to message #892672] Fri, 29 June 2012 14:16 Go to previous messageGo to next message
BIRT has extension points for just about everything :> The emitter
extension points allow a developer to add an emitter that they code to a
running system. Dev Share on birt-exchange.org has some examples of
people implementing their own emitters. In addition you may want to
have a look at the tribix emitters on source forge.
Jason
> generation?
Jason Weathersby
BIRT Exchange
Re: BIRT support for PDF and Excel report Generation [message #893231 is a reply to message #892802] Tue, 03 July 2012 05:57 Go to previous message
ok. Thank you, this is really helpful.
Previous Topic:White space where rows are empty
Next Topic:JDBC Driver problem for MSSQL- Schema not showing up in Data Source
Current Time: Thu May 23 00:09:43 EDT 2013
Powered by FUDForum. Page generated in 0.01873 seconds
