Home » Eclipse Projects » Eclipse 4 » Official upgrade route for 3.x to Juno
Official upgrade route for 3.x to Juno [message #892921] Sun, 01 July 2012 18:12 Go to next message
Chris Bruniges is currently offline Chris Bruniges
What's the official upgrade route for Eclipse 3.x (specifically Indigo) to Juno?
From a search on stack overflow (easiest-way-to-upgrade-eclipse-3-7-to-4-2-juno - sorry won't let me post links) it would seem to be that you need to start from scratch, which is somewhat of a hassle.
I know you can add your software through file->import software from existing, and some preferences through the same, but it doesn't seem to catch perspectives and upgrade sites. I'm not sure what else it's missing. Adding all this stuff in manually when you're being paid to write code is a bit...
Otherwise, I've tried adding the juno update site, but I seem to get a few conflicts from everything else, so I'm not sure if this is such a good idea?
If there's an upgrade guide specific to Juno that I've missed that would be great?
Thanks in advance,
Chris
Re: Official upgrade route for 3.x to Juno [message #892923 is a reply to message #892921] Sun, 01 July 2012 18:57 Go to previous messageGo to next message
Bob Lazare is currently offline Bob Lazare
No way for me.. I've done a fresh install of eclipse 4.2.0 (Juno).
But you keep all your settings and project in your workspace...
So it's Ok...
Re: Official upgrade route for 3.x to Juno [message #892925 is a reply to message #892923] Sun, 01 July 2012 19:17 Go to previous message
I know project settings (which compiler is used to compile foo-bar, what files are included and source) are kept there, are the UI settings there as well?
I'm pretty sure you're right and UI settings are there too, but either way, opening the workspace with 4.2 on Ubuntu doesn't seem to acknowledge them. The perspectives are still in their default one-screen has it all look. Right clicking reset on a perspective, or switching to a different perspective doesn't do anything either.
Exiting Juno and opening the same workspace with Indigo has my customised perspectives, so it doesn't seem like they have been clobbered by anything...
Previous Topic:Activity bindings vs model processors
Next Topic:Eclipse Juno on Fedora 17 update problems
Current Time: Tue May 21 23:53:21 EDT 2013
Powered by FUDForum. Page generated in 0.03871 seconds
