Home » Eclipse Projects » BIRT » Bug 382145 - Render Task order of magnitude slower in BIRT 3.7.2 than BIRT 2.6.2
Bug 382145 - Render Task order of magnitude slower in BIRT 3.7.2 than BIRT 2.6.2 [message #892582] Thu, 28 June 2012 12:25 Go to next message
David Schlosnagle is currently offline David Schlosnagle
While upgrading from BIRT 2.6.2 to 3.7.2 (and 4.2) we have encountered severe performance degradation with BIRT's render tasks. We have filed bug 382145 to address this issue, and I have provided a patch against BIRT's master branch that brings performance back in line with 2.6.2. I would like to know what the next steps are in having the patch reviewed and applied to BIRT 4.2.x.
I performed a YourKit tracing profiling of the attached testcase with BIRT
3.7.2, and discovered that there are a number of areas for improvement in the
archive file implementation added to BIRT 3.7. The attached profiler
screenshots show the following major hot spots and the related changes in my patch:
org.eclipse.birt.core.archive.compound.ArchiveFileV3.listEntries(String)
  • The current implementation of this method does an O(N) iteration over all entries to find the entries that begin with the specified name pattern. This is inefficient for large numbers of entries and repeated uses of this method then become exponentially costly.
  • I refactored this to use the Ext2FileSystem methods that provide an Iterable<String> of entries that begin with the specified name pattern. In combination with changes to EntryTable this becomes O(log N).
org.eclipse.birt.core.archive.compound.v3.EntryTable.write()
  • The current implemention copies the keySet, sorts it, then iterates over the entries get()ing each from the backing entry map.
  • I refactored the entry map to use a TreeMap to provide an always sorted map. This allows us to avoid the array copy and sort. Additionally, I added a new listEntries(String) method that allows for O(log N) sub-tree searches via SortedMap.tailMap(String) and the new PrefixedIterable class. The listEntries() method was renamed to listAllEntries(), and both listAllEntries() and listEntries(String) now return an Iterable<String> to simplify their usage.
org.eclipse.birt.data.engine.impl.DataEngineImpl.addShutdownListener(IShutdownListener)
  • The current implementation of this method does an O(N) iteration over all listener entries to determine whether a listener has already been added. When there are large numbers of listeners (e.g. one per result from org.eclipse.birt.data.engine.impl.ResultIterator.addEngineShutdownListener()), adding and removing become very expensive operations.
  • I refactored this to use a LinkedHashSet to provide O(1) add and remove operations.
Overall the attached patch changes bring the RenderTask times back in line with
BIRT 2.6.2, and help the RunTask slightly.
Before fix:
Report generated (RunTask): 60,354ms.
Report rendered (RenderTask): 135,915ms.
After fix:
Report generated (RunTask): 44,837ms.
Report rendered (RenderTask): 12,123ms.
Dave
Re: Bug 382145 - Render Task order of magnitude slower in BIRT 3.7.2 than BIRT 2.6.2 [message #892794 is a reply to message #892582] Fri, 29 June 2012 13:49 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
David
Thanks for all the details and the patch. The dev team is evaluating
the path now I believe.
Jason
> in the
> in my patch:
> from
> operations.
> line with
> Before fix:
> After fix:
> Dave
Jason Weathersby
BIRT Exchange
Previous Topic:Group Totals are not calculated correctly if Table > Properties > Sort By Groups is set to Fal
Next Topic:Bug on the two dimensional with depth chart?
Current Time: Sat May 25 15:34:33 EDT 2013
Powered by FUDForum. Page generated in 0.01757 seconds
