| app doesn't open any view nor editor after update to juno [message #892791] |
Fri, 29 June 2012 13:11  |
Luiz E. Messages: 97 Registered: September 2010 |
Member |
I have a RCP app built with Eclipse 3.7. Today I updated to Juno, with the following target definition:
<location includeAllPlatforms="false" includeConfigurePhase="false" includeMode="planner" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.platform.feature.group" version="4.2.0.v20120608-135145-9JF7BHV8FyMteji0Oi_ePMz0xuZ8TVo7lV0z0ecb"/>
<unit id="org.eclipse.equinox.executable.feature.group" version="3.6.0.v20120522-1813-7P7OG2BFLWUl7UmbVUO9iCm"/>
<unit id="org.eclipse.persistence.jpa.feature.group" version="2.4.0.v20120608-r11652"/>
<repository location="http://download.eclipse.org/releases/juno"/>
</location>
When I click to open a view, the SQL that loads the records that are shown on view runs fine, but the view doesn't open
I thought the problem could be with perspective or something else, but it wasn't
this is my `Perspective` class
public void createInitialLayout(IPageLayout layout) {
//IPartService partService = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getPartService();
//partService.addPartListener(new PerspectiveListenerAdapter());
this.layout = layout;
String editorAreaId = layout.getEditorArea();
layout.createPlaceholderFolder(FI_TOP, IPageLayout.TOP, ratioTop, editorAreaId);
layout.createPlaceholderFolder(FI_BOTTOM, IPageLayout.BOTTOM, ratioBottom, editorAreaId);
//layout.setEditorAreaVisible(false);
Everything that is commented was discommented before (and doesn't made ant difference).
Any ideas?
Thanks in advance and sorry abou my english
| Re: app doesn't open any view nor editor after update to juno [message #894509 is a reply to message #894148] |
Mon, 09 July 2012 09:39  |
Member |
Well, thats the exception I get when I try to open an editor
java.lang.IllegalArgumentException:
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:128)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:213)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.addPart(PartServiceImpl.java:756)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.addPart(PartServiceImpl.java:924)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:946)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3071)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:2996)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2978)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2974)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2933)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2916)
at br.com.germantech.ecf.aplicacao.commands.OpenEmissaoNFeEditor.execute(OpenEmissaoNFeEditor.java:22)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:851)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:744)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:728)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:667)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at br.com.germantech.ecf.aplicacao.internal.Application.start(Application.java:39)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.01777 seconds
