| [CDO/Dawn] Webcomponent [message #892577] |
Thu, 28 June 2012 12:14  |
is the Dawn web component still alive or are there plans to continue the
development? I looked through the git repositories and could not find
the plugins mentioned in the Getting_Started_With_Dawn_Web tutorial.
Best regards
Thomas
| Re: [CDO/Dawn] Webcomponent [message #892777 is a reply to message #892610] |
Fri, 29 June 2012 11:09   |
Am 28.06.2012 19:37, schrieb Martin Flügge:
> Am 28.06.2012 19:28, schrieb Eike Stepper:
>> Am 28.06.2012 18:14, schrieb Thomas Forster:
>>> Hi,
>>> the development? I looked through the git repositories and could not
>>> find the plugins mentioned in the Getting_Started_With_Dawn_Web tutorial.
>> I hope that Martin can comment on this...
> Currently there is no development in this area, sorry.
> You should find the bundles in the CDO incubator repository.
> http://git.eclipse.org/c/cdo/cdo.incubator.git
> Cheers,
> Martin
>> Cheers
>> /Eike
>> http://www.esc-net.de
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
yesterday I played around a little bit and got the web server running
with latest cdo/dawn releases. In the debugger I could assure that the
servlet responds, the renderer returns something, however the diagram is
not displayed in the browser. I assume it is a dependency to the plug-in
org.prototypejs (declared in the org.eclipse.emf.cdo.dawn.web plug-in),
which I threw out of the dependencies as I had not really a clue where
to find that plug-in - and it still compiled.
Any idea where to find that plug-in?
The second question is whether you generated the Web based Java script
representation out of the GMF genmodel and how this could be performed?
I saw a Paper where oaw was mentioned (if I'm not mistaken), are there
any scripts available?
Regards Thomas
| Re: [CDO/Dawn] Webcomponent [message #892891 is a reply to message #892777] |
Sun, 01 July 2012 09:32   |
Martin Fluegge Messages: 141 Registered: July 2009 |
Am 29.06.2012 17:09, schrieb Thomas Forster:
>>>> Hi,
>>>> tutorial.
>> Cheers,
>> Martin
>>> Cheers
>>> /Eike
The bundle should be part of the external feature mentioned in the tuorial:
http://mfdawn.sourceforge.net/dawn/
or you can get it from the specific SVN:
https://mfdawn.svn.sourceforge.net/svnroot/mfdawn/trunk/Dawn/plugins/org.prototypejs
No, currently there is no generator available for the editor specific
web stuff. It is written by hand (or actually generated by a very old
and outdated generator and then adapted by hand)
No, the first generator based on the old version of Dawn. When porting
it to Eclipse/CDO I did not migrate the generator because to many things
changed.
Martin
> Regards Thomas
| Re: [CDO/Dawn] Webcomponent [message #893385 is a reply to message #892987] |
Tue, 03 July 2012 15:08  |
Am 02.07.2012 10:34, schrieb Thomas Forster:
> Am 01.07.2012 15:32, schrieb Martin Flügge:
>> changed.
> Thanks, it works,
You are welcome :)
> Regards
> Thomas
FUDForum. Page generated in 0.01822 seconds
