Home » Eclipse Projects » BIRT » Does Birt 2.3.x support IE9?
Does Birt 2.3.x support IE9? [message #892188] Wed, 27 June 2012 07:07 Go to next message
smith link is currently offline smith link
Birt 2.3.x
tomcat 6
IE9
the report viewer only show the progress bar,and cannot get result.
Does the Birt 2.3.x support IE9?
  • Attachment: 3.jpg
    (Size: 18.38KB, Downloaded 44 times)
Re: Does Birt 2.3.x support IE9? [message #892542 is a reply to message #892188] Thu, 28 June 2012 10:51 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
It is not on the support matrix for 2.3.2, mainly because ie9 was not
out when 2.3.2 was released. The latest versions of BIRT are tested on
ie9. Can you try one of those?
Jason
On 6/27/2012 7:07 AM, smith link wrote:
> Birt 2.3.x
> tomcat 6
> IE9
Jason Weathersby
BIRT Exchange
Re: Does Birt 2.3.x support IE9? [message #892544 is a reply to message #892542] Thu, 28 June 2012 10:55 Go to previous messageGo to next message
BTW if you cant upgrade you could try running IE9 in compatibility mode.
You may also be interested in this bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=360068
Jason
> Jason
>> Birt 2.3.x
>> tomcat 6
>> IE9
Jason Weathersby
BIRT Exchange
Re: Does Birt 2.3.x support IE9? [message #892667 is a reply to message #892544] Fri, 29 June 2012 01:48 Go to previous message
Thanks a lot. Jason
Previous Topic:Zero Display ...
Next Topic:Group Totals are not calculated correctly if Table > Properties > Sort By Groups is set to Fal
Current Time: Wed May 22 03:55:55 EDT 2013
Powered by FUDForum. Page generated in 0.01728 seconds
