Home » Eclipse Projects » Platform - User Assistance (UA) » Simple Cheat Sheet Editor Bug?
Simple Cheat Sheet Editor Bug? [message #892661] Fri, 29 June 2012 00:32
Patrick S is currently offline Patrick S
Hi Guys,
I can't find any thread in forum and bugzilla related to this issue. Please help me identify if this is a bug or something else that cause it.
When editing simple cheat sheet using "Simple Cheat Sheet Editor", under Definition tab (or GUI) instead of direct XML Source editing, it messes up XML tags.
All I did was using its menu to Add Step then edit Title and Body then save it. Add few more Steps and/or Sub-Steps and move it up and down. It then messes up the XML source.
Do any of you have this problem? Perhaps I need to re-download Eclipse?
FYI, I'm using Eclipse Classic SDK v3.7.2 running on Ubuntu 10.10.
Previous Topic:RAP 1.5 Eclipse HelpSystem Problem
Next Topic:Indexing PDF in Eclipse Help
Current Time: Mon May 20 18:14:14 EDT 2013
Powered by FUDForum. Page generated in 0.01502 seconds
