Home » Eclipse Projects » EclipseLink » How to prevent EL from creating Reference ReadAllQuery
| How to prevent EL from creating Reference ReadAllQuery [message #892659] |
Fri, 29 June 2012 00:29  |
warz warz Messages: 6 Registered: May 2012 |
Junior Member |
I have a very frequent problem that involves entities and query relationships being referenced when one object is queried. From the stack trace below, the only query i agree with is the first one where i am directly querying for the object. I have set up a few weaving options to prevent this with an example of persitence.xml file:
<property name="eclipselink.ddl-generation" value="none"/>
<property name="eclipselink.ddl-generation.output-mode" value="database"/>
<property name="eclipselink.weaving" value="static"/>
<property name="eclipselink.logging.level" value="FINEST"/>
<property name="eclipselink.weaving.internal" value="false"/>
<property name="eclipselink.weaving.fetchgroups" value="false"/>
<property name="eclipselink.weaving.changetracking" value="false"/>
All of my @OneToMany, @ManyToMany and @OneToOne relationships have the keyword but there might be a JoinFetch left-join query hint conflict in my query below:
EntityManager entityManager = factory.createEntityManager();
/*Create a data structure to hold a list of users in our database*/
UserAccount tempUser = null;
try {
UserAccount user = (UserAccount)entityManager.createQuery("SELECT user FROM UserAccount user where user.username = :username")
.setParameter ("username", username).setHint("eclipselink.left-join-fetch", "u.person.address").setHint("eclipselink.left-join-fetch", "u.person.school.address")
.getSingleResult();
return user;
} catch (EmptyResultDataAccessException e) {
//There is no user with this username - do something
return null;
} catch (NonUniqueResultException e) {
//There is more than one user with this username - do something
entityManager.close();
How can i prevent this so that when i ask for a single object, i only get that object and No injenction and autowiring does not happen (I am using Spring Roo which should not generate any SQL)
Stack Trace
[EL Finest]: connection: 2012-06-28 23:03:07.942--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:07.942--ServerSession(1021946387)--Connection(678613912)--Thread(Thread[main,5,main])--SELECT userID, EMAIL, ISLOCKED, LOGINATTEMPTS, passwordHash, PASSWORDRESETDATE, passwordSalt, USERNAME, version, PERSON_personID FROM USERACCOUNT WHERE (USERNAME = ?)
bind => [admin]
[EL Finest]: connection: 2012-06-28 23:03:07.95--ServerSession(1021946387)--Connection(1395706699)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
2012-06-28 23:03:07,953 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.UserAccount': PersistenceElement for transient javax.persistence.EntityManager org.bixin.dugsi.domain.UserAccount.entityManager
2012-06-28 23:03:07,954 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'entityManagerFactory'
2012-06-28 23:03:07,954 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.UserAccount': AutowiredFieldElement for private java.lang.Boolean org.bixin.dugsi.domain.UserAccount.isLocked
2012-06-28 23:03:07,954 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,954 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,954 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,955 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,955 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,955 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,955 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,956 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,956 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,956 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,956 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,957 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,957 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,957 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,957 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,958 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,958 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,958 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,958 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.UserAccount': AutowiredFieldElement for private int org.bixin.dugsi.domain.UserAccount.loginAttempts
2012-06-28 23:03:07,958 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,959 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,959 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,962 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,963 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,963 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,963 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,963 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,964 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,964 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,964 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,964 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
[EL Finest]: query: 2012-06-28 23:03:07.965--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="person" referenceClass=Person )
[EL Finest]: connection: 2012-06-28 23:03:07.966--ServerSession(1021946387)--Connection(558455736)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:07.966--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:07.967--ServerSession(1021946387)--Connection(1462017562)--Thread(Thread[main,5,main])--SELECT personID, TYPE, DATEADDED, FIRSTNAME, LASTNAME, MIDDLENAME, ACTIVE, BIRTHDAY, EMAILADDRESS, ETHNICITY, GENDER, HISPANIC, IMAGEPATH, MARITAL, NATIVELANGUAGE, PRIMARYTELEPHONE, RELIGIOUSAFFILIATION, SECONDARYTELEPHONE, version, addressID, schoolID, MAJOR, studentId FROM PERSON WHERE (personID = ?)
bind => [10000]
[EL Finest]: connection: 2012-06-28 23:03:07.97--ServerSession(1021946387)--Connection(558455736)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
2012-06-28 23:03:07,970 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.Student': PersistenceElement for transient javax.persistence.EntityManager org.bixin.dugsi.domain.Person.entityManager
2012-06-28 23:03:07,971 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'entityManagerFactory'
[EL Finest]: query: 2012-06-28 23:03:07.972--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="address" referenceClass=Address )
[EL Finest]: connection: 2012-06-28 23:03:07.972--ServerSession(1021946387)--Connection(293359801)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:07.972--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:07.973--ServerSession(1021946387)--Connection(2023205542)--Thread(Thread[main,5,main])--SELECT addressID, CITY, COUNTRY, STATE_US, STREETADDRESS, STREETADDRESS2, version, ZIPCODE FROM ADDRESS WHERE (addressID = ?)
bind => [1]
[EL Finest]: connection: 2012-06-28 23:03:07.975--ServerSession(1021946387)--Connection(293359801)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
2012-06-28 23:03:07,975 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.Address': PersistenceElement for transient javax.persistence.EntityManager org.bixin.dugsi.domain.Address.entityManager
2012-06-28 23:03:07,976 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'entityManagerFactory'
[EL Finest]: query: 2012-06-28 23:03:07.978--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="school" referenceClass=School )
[EL Finest]: connection: 2012-06-28 23:03:07.978--ServerSession(1021946387)--Connection(2038638222)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:07.978--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:07.979--ServerSession(1021946387)--Connection(291009269)--Thread(Thread[main,5,main])--SELECT schoolID, ACTIVE, ADMISSIONSEMAILADDRESS, ADMISSIONSPHONE, CODE, description, HELPGENERALEMAILADDRESS, NAME, PRIMARYPHONE, version, addressID FROM SCHOOL WHERE (schoolID = ?)
bind => [1]
[EL Finest]: connection: 2012-06-28 23:03:07.982--ServerSession(1021946387)--Connection(2038638222)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
2012-06-28 23:03:07,983 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.School': PersistenceElement for transient javax.persistence.EntityManager org.bixin.dugsi.domain.School.entityManager
2012-06-28 23:03:07,983 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'entityManagerFactory'
[EL Finest]: query: 2012-06-28 23:03:07.984--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="address" referenceClass=Address )
[EL Finest]: connection: 2012-06-28 23:03:07.984--ServerSession(1021946387)--Connection(1619572824)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:07.984--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:07.985--ServerSession(1021946387)--Connection(805227243)--Thread(Thread[main,5,main])--SELECT addressID, CITY, COUNTRY, STATE_US, STREETADDRESS, STREETADDRESS2, version, ZIPCODE FROM ADDRESS WHERE (addressID = ?)
bind => [3]
[EL Finest]: connection: 2012-06-28 23:03:07.986--ServerSession(1021946387)--Connection(1619572824)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
2012-06-28 23:03:07,986 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.Address': PersistenceElement for transient javax.persistence.EntityManager org.bixin.dugsi.domain.Address.entityManager
2012-06-28 23:03:07,987 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'entityManagerFactory'
2012-06-28 23:03:07,989 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.UserAccount': PersistenceElement for transient javax.persistence.EntityManager org.bixin.dugsi.domain.UserAccount.entityManager
2012-06-28 23:03:07,990 [main] DEBUG org.springframework.beans.factory.support.DefaultListableBeanFactory - Returning cached instance of singleton bean 'entityManagerFactory'
2012-06-28 23:03:07,990 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.UserAccount': AutowiredFieldElement for private java.lang.Boolean org.bixin.dugsi.domain.UserAccount.isLocked
2012-06-28 23:03:07,990 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,990 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,990 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,990 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,991 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,991 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,991 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,991 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,992 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,992 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,992 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,992 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,992 [main] DEBUG org.springframework.beans.factory.annotation.InjectionMetadata - Processing injected method of bean 'org.bixin.dugsi.domain.UserAccount': AutowiredFieldElement for private int org.bixin.dugsi.domain.UserAccount.loginAttempts
2012-06-28 23:03:07,993 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,993 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
2012-06-28 23:03:07,993 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,993 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,994 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
2012-06-28 23:03:07,994 [main] DEBUG org.springframework.core.env.StandardEnvironment - Initializing new StandardEnvironment
2012-06-28 23:03:07,994 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemProperties] PropertySource with lowest search precedence
2012-06-28 23:03:07,994 [main] DEBUG org.springframework.core.env.StandardEnvironment - Adding [systemEnvironment] PropertySource with lowest search precedence
[EL Finest]: transaction: 2012-06-28 23:03:07.995--UnitOfWork(1411077618)--Thread(Thread[main,5,main])--[EL Finest]: query: 2012-06-28 23:03:08.005--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadAllQuery(name="registrations" referenceClass=Registration )
[EL Finest]: connection: 2012-06-28 23:03:08.006--ServerSession(1021946387)--Connection(939536212)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:08.006--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:08.007--ServerSession(1021946387)--Connection(337858693)--Thread(Thread[main,5,main])--SELECT registrationId, SEMESTERTAKEN, version, YEAR, semesterCourseId, personID FROM REGISTRATION WHERE (personID = ?)
bind => [10000]
[EL Finest]: connection: 2012-06-28 23:03:08.008--ServerSession(1021946387)--Connection(939536212)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
[EL Finest]: query: 2012-06-28 23:03:08.009--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadAllQuery(name="schools" referenceClass=ApplicantSchool )
[EL Finest]: connection: 2012-06-28 23:03:08.011--ServerSession(1021946387)--Connection(1101985688)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:08.011--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:08.012--ServerSession(1021946387)--Connection(1174486488)--Thread(Thread[main,5,main])--SELECT applicantSchoolID, CREDITSCOMPLETED, FROMMONTH, FROMYEAR, GPA, NAME, SCHOOLTYPE, TOMONTH, TOYEAR, version, APPLICANT_personID FROM APPLICANTSCHOOL WHERE (APPLICANT_personID = ?)
bind => [10000]
[EL Finest]: connection: 2012-06-28 23:03:08.013--ServerSession(1021946387)--Connection(1101985688)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
[EL Finest]: query: 2012-06-28 23:03:08.02--ServerSession(1021946387)--Thread(Thread[main,5,main])--Execute query ReadAllQuery(name="persons" referenceClass=Person )
[EL Finest]: connection: 2012-06-28 23:03:08.021--ServerSession(1021946387)--Connection(304483725)--Thread(Thread[main,5,main])--Connection acquired from connection pool [read].
[EL Finest]: connection: 2012-06-28 23:03:08.021--ServerSession(1021946387)--Thread(Thread[main,5,main])--reconnecting to external connection pool
[EL Fine]: sql: 2012-06-28 23:03:08.022--ServerSession(1021946387)--Connection(4435274)--Thread(Thread[main,5,main])--SELECT personID, TYPE, DATEADDED, FIRSTNAME, LASTNAME, MIDDLENAME, ACTIVE, BIRTHDAY, EMAILADDRESS, ETHNICITY, GENDER, HISPANIC, IMAGEPATH, MARITAL, NATIVELANGUAGE, PRIMARYTELEPHONE, RELIGIOUSAFFILIATION, SECONDARYTELEPHONE, version, addressID, schoolID, MAJOR, studentId FROM PERSON WHERE (addressID = ?)
bind => [1]
[EL Finest]: connection: 2012-06-28 23:03:08.023--ServerSession(1021946387)--Connection(304483725)--Thread(Thread[main,5,main])--Connection released to connection pool [read].
| Re: How to prevent EL from creating Reference ReadAllQuery [message #893328 is a reply to message #892817] |
Tue, 03 July 2012 10:46  |
Chris Delahunt Messages: 863 Registered: July 2009 |
Yes, weaving is required for OneToOne relationships to be lazy. I would try again removing all the eclipselink.weaving.* settings, and run the static weaver on your jar before deploying (and keeping the eclipselink.weaving = static property) and see if this helps in conjunction with refreshing the entity as mentioned in my first post.
Best Regards,
Chris
Current Time: Fri May 24 05:59:36 EDT 2013
Powered by FUDForum. Page generated in 0.06057 seconds
