Home » Eclipse Projects » Equinox » Problem running OSGI in eclipse (-dev mode)
Problem running OSGI in eclipse (-dev mode) [message #892543] Thu, 28 June 2012 10:55 Go to next message
Elena Perez is currently offline Elena Perez
I'm having some problems in a small OSGI project.
In one of the bundles I install and start programatically another bundle that wasn't installed before.
Nevertheless, when I run the project in Eclipse, jumps a ClassNot FoundException in the implementation of the bundle.
I believe it's because Eclipse automatically starts the project with a -dev parameter (development mode) pointing at dev.properties file where it specifies the bin folder where it builds each bundle. Obviously this dev.properties file created by Eclipse doesn't include the bundle I'll install later.
Is there any way to disable the dev mode when running with an OSGI configuration in Eclipse or, at least, to use a customized dev.properties file (eclipse creates and uses one created automatically and that updates everytime we try to run)?
Thank you
Elena
Re: Problem running OSGI in eclipse (-dev mode) [message #892783 is a reply to message #892543] Fri, 29 June 2012 12:20 Go to previous message
The problem is when I try to start a bundle programmatically like this:
public void charge(String location){
try {
bundle2= bundleContext.installBundle(location);
bundle2.start();
} catch (BundleException e) {
e.printStackTrace();
the bundle installs without problems but when it tries to start jumps a classNotFoundException for the implementation of the bundle I just installed. The same thing happens when I try to do the same thing in the osgi console.
Is there any way to fix this problem? It can be other thing beside the dev.properties file?
Thank you
Elena
Previous Topic:Equinox console "log" command?
Next Topic:Launching Equinox via srvany.exe
Current Time: Thu May 23 05:58:18 EDT 2013
Powered by FUDForum. Page generated in 0.04004 seconds
