Paul Ramsden Messages: 75 Registered: February 2011 Location: BW, Germany
Member
I have been trying to use the following expression in a highlight rule.
row["Status"].charAt(0) equalTo '1'
It never seems to work.
I also tried
new String(row["Status"]).charAt(0) equalTo '1'
row["Status"].charAt(0) == '1' IsTrue
... no luck
Am I doing something wrong here?
On a related point:
I believe that the data is correct but I would like to debug this or spit out some kind of trace to make sure. How could I do this?
Is row["Status"] a string? Take a look at the attached example. Select
the product code and see the highlight rule.
Jason
> I also tried
> ... no luck
> On a related point:
Jason
> I also tried
> ... no luck
> On a related point:
Jason
> I also tried
> ... no luck
> On a related point:
Jason
> I also tried
> ... no luck
> On a related point:
Jason
> I also tried
> ... no luck
> On a related point:
Jason
> I also tried
> ... no luck
> On a related point:
Also may want to put a check in for null, because this will most likely
cause the highlight to fail.
Jason
> Jason
>> I also tried
>> ... no luck
>> On a related point:
Member
Thanks for the replies.
I am pretty certain that the value is a string and is not null. The string is always 2 chars, xy, where x indicates attendance (0 or 1) and y is the role (., M, B or X). The role is output as text in the cell. The attendance is used highlight the cell (change background colour).
The role value does appear correctly using normal data binding (e.g. dataSetRow["Day1"].charAt(1))
I am not certain why this happening. Can you reproduce with the sample db?
Jason
> Is it possible to debug javascript?
