Home » Eclipse Projects » BIRT » Java Crashing when using BIRT within RCP
Java Crashing when using BIRT within RCP [message #892507] Thu, 28 June 2012 09:41
Gourishankar Menon is currently offline Gourishankar Menon
I am using Juno with BIRT 4.2 to generate a dashboard in RCP (e4 Application). I am using a "scripted datasource". The report is generating fine. I can move around the report, change the parameters etc. The application is also working just fine. The issue I have is when I try to exit the application it crashes and dumps a javacore. The way I am displaying the report is as follows
WebViewer.display(reportName, browser, reportParams);
Could I get some help on why it would crash when exiting ?
Thank you
Gouri
Previous Topic:Error while starting the GlassFish server + BIRT 3.7.1
Next Topic:Birt Memory Usage
Current Time: Sat May 18 16:48:04 EDT 2013
Powered by FUDForum. Page generated in 0.01543 seconds
