Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » How can I avoid a time-out in executing an automated GUI test?
How can I avoid a time-out in executing an automated GUI test? [message #89211] Fri, 01 December 2006 10:19 Go to next message
Eclipse User
Originally posted by: mangelillo.tirawireless.com
I've started using the TPTP Automated GUI Tester to test our software but
I've run into a snag. Some of the test cases take a bit of time to
complete and when I execute the test I get a time-out exception. It says
"A time-out occured while running command MacroCommand" at
org.eclipse.tptp.auto.gui.internal.commands.MacroCommandsShe ll.playback(MacroCommandShell.java:1040)
Is there an option to increase the time alloted for test execution or some
way to get the source so I can edit it?
Marc
Re: How can I avoid a time-out in executing an automated GUI test? [message #89242 is a reply to message #89211] Fri, 01 December 2006 10:42 Go to previous message
Eclipse User
I just found the answer to my question. In the Behavior tab of your
testsuite, you can change the "Time-out Threshold for Each Command" in the
Detailed Properties section at the bottom right.
M
Previous Topic:2006 Tester's Choice Awards
Next Topic:HTTP Generate Wizard
Current Time: Wed May 22 00:47:24 EDT 2013
Powered by FUDForum. Page generated in 0.01413 seconds
