Home » Eclipse Projects » Jubula » Plugin to recognize all widgets or controls
Plugin to recognize all widgets or controls [message #890271] Thu, 21 June 2012 13:41 Go to next message
Amanda Mitchell is currently offline Amanda Mitchell
I am using Jubula to test a rcp application. In the application there are tabbed panes that contain widget buttons, labels, composites, and canvases. Using Jubula's object mapping, it recognizes the buttons and labels, but not the composites or canvases. Since these are all widgets and controls, is there some plug in already available that simply recognizes all Widgets or all controls?
I have tried having a developer create an extended plugin for me to recognize these controls. However, in doing so other issues arose with recognition of other objects, such as the names of the tabbed panes.
That is why I thought I would ask if a general plug-in that would recognize all Widgets or Controls is already available. Or if that isn't available, is there a plugin that would allow Composites to be recognized?
Thank you for your help
Re: Plugin to recognize all widgets or controls [message #890357 is a reply to message #890271] Fri, 22 June 2012 02:33 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
Can you give an example of what type of composites you are trying to map? The canvas (if it is a GEF canvas) should be mappable, and for the others, a screenshot would help to understand better what you are trying to do.
Alex
Re: Plugin to recognize all widgets or controls [message #891950 is a reply to message #890271] Tue, 26 June 2012 12:23 Go to previous messageGo to next message
We implement a custom expand bar is made from a org.eclipse.swt.widgets.Composite
We have a color fill well that uses org.eclipse.swt.widgets.Canvas that has a paint listener to draw the appropriate content.
Additionally we have a panel that has multiple sections of information that uses org.eclipse.ui.forms.widgets.Section, that I also cannot click on.
The screenshot show the color fill well and the custom expand bar.
Thanks for your help
Re: Plugin to recognize all widgets or controls [message #892406 is a reply to message #891950] Thu, 28 June 2012 03:07 Go to previous message
Based on the picture, it looks like they are indeed components that aren't supported out of the box. There is a good thread here containing a link to an excellent blog post, there's another thread here with some extra information, and more descriptions here and here that may be of use. There is also the extension manual (downloadable from the Jubula page) and the option of having one of our guys do it for you Wink
HTH,
Alex
Previous Topic:How to select which records of a data set to use
Next Topic:Can't have 2 Check component text event handlers
Current Time: Sat May 25 02:19:06 EDT 2013
Powered by FUDForum. Page generated in 0.01717 seconds
