Home » Newcomers » Newcomers » Android Eclipse USB and Linux
Android Eclipse USB and Linux [message #892383] Wed, 27 June 2012 19:54 Go to next message
Marc Chamberlin is currently offline Marc Chamberlin
After a LOT of Googling I am not finding any answers to this question I
have, so hopefully someone here has forged this path and can enlighten
me? I have set up Eclipse to develop for Android and gotten some success
with using a couple of the Android simulators. (Most don't seem to work
out of the box) Anywise I now would like to use a real Android device (I
have an ASUS pad to play with, will be getting an Android phone shortly
though I dunno yet which one) and understand I can do so using a USB
connection.
I presume (correct me if I am wrong!) I must use a peer to peer (also
called a host to host or crossover) USB cable with Type A connectors on
each end? (at least for the pad, dunno what sort of connector the phone
will have...) Looking around I found several companies selling crossover
cables but all I can find are supported with Windows drivers. From what
I can grok, it appears that one must have a special driver in order to
have a protocol that will allow communication to take place between two
hosts making each appear as a device to the other, hence the need for a
special driver. Trouble is, I am developing under Linux (openSuSE12.1 to
be exact) so before I go and order one of these cables I would like to
know if A) Does Linux/Eclipse support these cables out of the box? B) If
not, can someone recommend a cable the is supported under Linux/Eclipse?
C) If so, I would still appreciate recommendations on what cables others
have had a good experience with....
Marc..
P.S. I didn't find an Eclipse newsgroup dedicated to Android development
under Eclipse, so my apologies in advance if this is an inappropriate
place to ask this question.
Re: Android Eclipse USB and Linux [message #892384 is a reply to message #892383] Wed, 27 June 2012 20:01 Go to previous message
David Wegener is currently offline David Wegener
> connection.
> Marc..
Google developed their Android development tools on top of Eclipse.
Eclipse forums don't provide support for Android development. You'll
need to find continue your search. Note that there is a sticky post at
the top of this forum that includes links to some forums that may
provide Android help.
Previous Topic:remote debugging question
Next Topic:uncheckout js file in clearcase7125 will expose fatal error when use wtp
Current Time: Fri May 24 20:57:13 EDT 2013
Powered by FUDForum. Page generated in 0.01637 seconds
