| JavaMail failes on virgo [message #889979] |
Wed, 20 June 2012 09:08  |
jacob hameiri Messages: 13 Registered: June 2012 |
Junior Member |
I am trying to send mail using JavaMail from a bundle, if I try the same code from a simple test jar ( not osgi ) on the same machine it succeeds.
this is my code:
Properties props = new Properties();
props.put("mail.smtp.host", "smtp.gmail.com");
props.put("mail.smtp.socketFactory.port", "465");
props.put("mail.smtp.socketFactory.class",
"javax.net.ssl.SSLSocketFactory");
props.put("mail.smtp.auth", "true");
props.put("mail.smtp.port", "465");
Session session = Session.getInstance(props,
new javax.mail.Authenticator() {
protected PasswordAuthentication getPasswordAuthentication() {
return new PasswordAuthentication(
"user@gmail.com", "password");
try {
Message message = new MimeMessage(session);
message.setFrom(new InternetAddress("user@gmail.com"));
message.setRecipients(Message.RecipientType.TO,
InternetAddress.parse("tomail@gmail.com"));
message.setSubject("Testing 123");
message.setText("test123");
// create the message part
MimeBodyPart messageBodyPart = new MimeBodyPart();
// fill message
messageBodyPart.setText("testing testing testing testing");
Multipart multipart = new MimeMultipart("mixed");
multipart.addBodyPart(messageBodyPart);
// Part two is attachment
DataSource source = new FileDataSource("/tmp/sample.pdf");
messageBodyPart.setDataHandler(new DataHandler(source));
messageBodyPart.setFileName("/tmp/sample.pdf");
// Put parts in message
message.setContent(multipart);
Transport.send(message);
System.out.println("Done");
} catch (MessagingException e) {
throw new RuntimeException(e);
this is the exception:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at mailsender.test.SendMail(test.java:232) ~[mailsender-bundle-2.2.1.5.jar/:na]
at mailsender.test.createReport(test.java:152) ~[mailsender-bundle-2.2.1.5.jar/:na]
at mailsender.test.eventjob.execute(EventJob.java:100) [mailsender-bundle-2.2.1.5.jar/:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [com.springsource.org.quartz-1.6.2.jar:1.6.2]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:525) [com.springsource.org.quartz-1.6.2.jar:1.6.2]
Caused by: javax.mail.MessagingException: Exception reading response
at com.sun.mail.smtp.SMTPTransport.readServerResponse(SMTPTransport.java:1462) ~[na:na]
at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1260) ~[na:na]
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:370) ~[na:na]
at javax.mail.Service.connect(Service.java:297) ~[com.springsource.javax.mail-1.4.0.jar:1.4]
at javax.mail.Service.connect(Service.java:156) ~[com.springsource.javax.mail-1.4.0.jar:1.4]
at javax.mail.Service.connect(Service.java:105) ~[com.springsource.javax.mail-1.4.0.jar:1.4]
at javax.mail.Transport.send0(Transport.java:168) ~[com.springsource.javax.mail-1.4.0.jar:1.4]
at javax.mail.Transport.send(Transport.java:98) ~[com.springsource.javax.mail-1.4.0.jar:1.4]
at mailsender.test.SendMail(test.java:227) ~[mailsender-bundle-2.2.1.5.jar/:na]
... 4 common frames omitted
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Alerts.java:174) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1731) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Handshaker.java:241) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Handshaker.java:235) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1206) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:136) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshaker.java:593) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Handshaker.java:529) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:925) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1170) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:785) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.AppInputStream.read(AppInputStream.java:75) ~[na:1.6]
at com.sun.mail.util.TraceInputStream.read(TraceInputStream.java:97) ~[na:na]
at java.io.BufferedInputStream.fill(BufferedInputStream.java:218) ~[na:1.6.0_33]
at java.io.BufferedInputStream.read(BufferedInputStream.java:237) ~[na:1.6.0_33]
at com.sun.mail.util.LineInputStream.readLine(LineInputStream.java:75) ~[na:na]
at com.sun.mail.smtp.SMTPTransport.readServerResponse(SMTPTransport.java:1440) ~[na:na]
... 12 common frames omitted
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:323) ~[na:1.6.0_33]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:217) ~[na:1.6.0_33]
at sun.security.validator.Validator.validate(Validator.java:218) ~[na:1.6.0_33]
at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:126) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:209) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:249) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1185) ~[na:1.6]
... 24 common frames omitted
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:174) ~[na:1.6.0_33]
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:238) ~[na:1.6.0_33]
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:318) ~[na:1.6.0_33]
... 30 common frames omitted
any ideas ?
[Updated on: Wed, 20 June 2012 10:13] Report message to a moderator
| Re: JavaMail failes on virgo [message #892194 is a reply to message #889979] |
Wed, 27 June 2012 07:29  |
Glyn Normington Messages: 1186 Registered: July 2009 |
Usually moving from conventional Java to OSGi is a matter of addressing class loading issues. We've seen some novelties in the area of security though, because of the way security is configured. I'm not sure what the problem is in this particular case. You might compare notes with this thread perhaps.
FUDForum. Page generated in 0.01535 seconds
