Home » Modeling » Epsilon » EVL validation fixes are not usable when having multiple EVL files(the not-so-old fixes are removed)
EVL validation fixes are not usable when having multiple EVL files [message #891875] Tue, 26 June 2012 07:58 Go to next message
Maarten Bezemer is currently offline Maarten Bezemer
Member
Hi all,
I am taking another look at the EVL validation fixes and am having another problem.
I use multiple EVL files for validation (generally grouped by object type to prevent a big and messy evl file). My problem is that the EvlValidator#validate() removes the old fixes before validating using:
EvlMarkerResolutionGenerator.INSTANCE.removeFixesFor(eObject);
This results in not so old fixes getting removed as well due to the multiple EVL files. Say if the 'first' EVL file found a problem for which a fix is available it gets registered. After that the 'second' EVL file is used for validation and the fix of the 'first' EVL file is removed already...
Is this a known problem, or should I open a new bug report?
First I have to fix some other things, but after that I am willing to take a look at it and provide a patch (if it indeed is a bug and not my error).
For example, the EVLFixInstance class could be extended by storing the EVL URI, so when remove fixes only the ones for a specific URI are included.
Note: The EVLFixInstance class is not in org.eclipse.epsilon.evl.emf.validation (but in org.eclipse.epsilon.evl) I would expect it to be present in the former plugin as it is a validation related class?
Re: EVL validation fixes are not usable when having multiple EVL files [message #891959 is a reply to message #891875] Tue, 26 June 2012 12:11 Go to previous messageGo to next message
Steffen Zschaler is currently offline Steffen Zschaler
Could you not import all of your EVL files from one central EVL file and
use that instead to run only a single round of validation?
Best,
Steffen
On 26/06/2012 12:58, Maarten Bezemer wrote:
> Hi all,
> another problem.
> removed already...
> my error).
> included.
Re: EVL validation fixes are not usable when having multiple EVL files [message #892134 is a reply to message #891959] Wed, 27 June 2012 03:47 Go to previous messageGo to next message
Member
Yes, that would be possible as work-around.
As I have made quite a few changes in the EVL validation already, I applied a 'hack' to make it usable for my current situation before I (or someone else) have time to properly fix it
Re: EVL validation fixes are not usable when having multiple EVL files [message #892151 is a reply to message #892134] Wed, 27 June 2012 04:48 Go to previous message
Member
Oops I started a thread on this subject before (lots of things on my head, it must have been slipped my mind).
Previous Topic:EGL/EOL java code
Next Topic:Global Variables in imported EOL
Current Time: Tue May 21 14:48:18 EDT 2013
Powered by FUDForum. Page generated in 0.02096 seconds
