| Damos proposal? [message #881622] |
Mon, 04 June 2012 19:49  |
Werner Keil Messages: 1067 Registered: July 2009 |
I hope I'm not ahead of any announcement here, but I saw a Tweet about the
Damos proposal:
http://www.eclipse.org/proposals/tools.damos/
And the first draft of that seems to be out at least a month now.
Either for actual representation of physical models (with Temperature
mentioned as an example by the draft) or for certain generated code
including markup like UCUM Damos seems extremely interesting to the UOMo
project and involved parties.
Could someone please list me as Interested Party on behalf of UOMo:
- Werner Keil, Eclipse UOMo
Werner
| Re: Damos proposal? [message #896884 is a reply to message #881622] |
Fri, 20 July 2012 05:46   |
Hi Andreas and all!
Koneki team is very interested in collaborating with Damos, and so is the M2M Industry Working Group. A modeling/code generation environment would be a great addition to the development framework we aim at establishing, and there could certainly be an M2M blocks library that'd provide components to acquire data on GPIOs, send data using specific encoding chains, etc.
I was wondering if you have anything to "easily" deploy the generated code on an actual target, or is it up to the developer to do it manually?
On a related note, you might be interested in our recently proposed project, Mihini, that aims at providing a Lua-based M2M framework that provides a scripting environment facilitating the access to HW I/Os, network, etc. It'd be interesting to see how one could benefit from targetting Mihini for the actual implementation of Damos' blocks (especially given that Mihini implements a collaborative scheduler)
Anyways, kudos for this proposal! I have been following Yakindu and Damos for a long time and I am thrilled to see you guys moving to Eclipse!
Benjamin.
FUDForum. Page generated in 0.01712 seconds
