Home » Newcomers » Newcomers » fortran source code analysis
fortran source code analysis [message #892018] Tue, 26 June 2012 16:34
Josh Hofling is currently offline Josh Hofling
Hi folks,
what I would like to do is the following.
I need to analyze an Fortran based source code in order to analyze and adapt a certain algorithm. The program reads a seperate txt as input data in order to perform an optimizations procedure.
So far I am having trouble to set up Eclipse Indigo to make it work proper...
(First time working with Fortran&Eclispe, please give me a little indulgence).
I am using Win7; 64.
What I´ve done so far:
- new project-> fortran project-> 'executable GNU Fortran on Windows'
- import 'existing code as makefile project'->imported folder, folder includes program & files
- 'toolchain for Indexer settings on MinGW GCC'
- Strg+B
If I run as fortran application: Launch failed. Binary not found..
So I tried run configuration and selected C:\MinGW64\mingwvars.bat for the fortran application.
Nothing seemed to happen, just the console is saying:
'Setting up environment for using MinGW with GCC from C:\MinGW64\.'
I don´t not what to do.
Thanks for helping
Previous Topic:How to make a source attachement in eclipse?
Next Topic:importing web project in eclipse
Current Time: Fri May 24 14:14:44 EDT 2013
Powered by FUDForum. Page generated in 0.01611 seconds
