Home » Newcomers » Newcomers » Eclipse start with a Splash and nothing else(eclipse doesn't display ide)
Eclipse start with a Splash and nothing else [message #891771] Mon, 25 June 2012 16:33 Go to next message
todd bailey is currently offline todd bailey
Hi All,
Running Fedora Linux r14 x64.
I've downloaded eclipse & JDK
eclipse-java-indigo-linux-gtk-x86_64.tar.gz,
eclipse-java-ganymede-SR2-linux-gtk-x86_64.tar.gz
jdk-7u5-linux-x64.rpm
THe JDK was installed and eclipse were extracted and stored in a local home folder.
I tried to the troubleshooting steps on the .ini file but couldn't determine if there was an issue or not. the ini file reads like this
-showsplash
org.eclipse.platform
-framework
plugins/org.eclipse.osgi_3.4.3.R34x_v20081215-1030.jar
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
I'm trying to start from a cmd line using this command
cd ~/eclipse; ./eclipse -vm /usr/bin/java java
in either indigo or ganymede, I see the splash screen but nothing else
Am I missing something?
Re: Eclipse start with a Splash and nothing else [message #891777 is a reply to message #891771] Mon, 25 June 2012 17:29 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
On 6/25/2012 2:33 PM, todd bailey wrote:
> Hi All,
> I've downloaded eclipse & JDK eclipse-java-indigo-linux-gtk-x86_64.tar.gz,
> eclipse-java-ganymede-SR2-linux-gtk-x86_64.tar.gz jdk-7u5-linux-x64.rpm
> home folder.
> -showsplash
> -framework
> -vmargs
> -Xms40m
> -Xmx256m
You might wish to configure eclipse.ini optimally as suggested by
http://wiki.eclipse.org/Eclipse.ini
Re: Eclipse start with a Splash and nothing else [message #891780 is a reply to message #891777] Mon, 25 June 2012 17:50 Go to previous messageGo to next message
OK, but there isn't enough information on that site.
Like I implied on original post already been there, done that.
I'm using the "defaults" as supplied.
more detail please
Do I need to install anything else to get eclipse to run?
thanks
[Updated on: Mon, 25 June 2012 18:28]
Report message to a moderator
Re: Eclipse start with a Splash and nothing else [message #891910 is a reply to message #891780] Tue, 26 June 2012 10:11 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
The link gives very detailed instructions on how to setup your eclipse.ini file. What else do you need?
Re: Eclipse start with a Splash and nothing else [message #891939 is a reply to message #891910] Tue, 26 June 2012 11:59 Go to previous message
... It gives "very detailed"...
Hardly, I'm no expert and haven't a clue what each parameter does nor what would be considered optimal.
The line "the exact contents will vary based on operating system and which Eclipse package" doesn't help. so if I have xxx installed on a yyy os then what? punt?
Lets say the file got corrupted, the wiki provides little guidance on what is required to rebuild it from scratch or recommended values.
But this point is moot, I emailed the instructor of the class I'm taking and in return sent a few (config?) files and answered a couple of questions on what was installed and where. Later his edits fixed the problem.
So the wiki is fine for those who are familiar with the product but not so much to the first time user.
Previous Topic:Console window error problem
Next Topic:How to make a source attachement in eclipse?
Current Time: Sun May 19 03:04:55 EDT 2013
Powered by FUDForum. Page generated in 0.01637 seconds
