| [SOLVED] Entity Class identity problem in OSGi after uninstalling/reinstalling persistence bundle [message #891606] |
Mon, 25 June 2012 06:53  |
GianMaria Romanato Messages: 41 Registered: July 2009 |
Member |
Hi all,
I am prototyping an OSGi enterprise application with EclipseLink JPA (snapshot) and Gemini JPA. The prototype is deployed in Eclipse Virgo.
I have a persistence unit included in a bundle. When the app starts everything works fine and JPA works as expected.
If (with OSGi running) I uninstall and re-install the bundle containing the persistence unit (i.e. I am hot-swapping the bundle) and then I try to use again the EMFBuilder and the EMF to obtain an EM and to perform a search, I get the following error:
java.lang.IllegalArgumentException: No [EntityType] was found for the key class [model.Client] in the Metamodel - please verify that the [Entity] class was referenced in persistence.xml using a specific <class>model.Client</class> property or a global <exclude-unlisted-classes>false</exclude-unlisted-classes> element.
org.eclipse.persistence.internal.jpa.metamodel.MetamodelImpl.entityEmbeddableManagedTypeNotFound(MetamodelImpl.java:174)
org.eclipse.persistence.internal.jpa.metamodel.MetamodelImpl.entity(MetamodelImpl.java:194)
org.eclipse.persistence.internal.jpa.querydef.AbstractQueryImpl.from(AbstractQueryImpl.java:97)
I believe that EclipseLink closes the EMF when the bundle is uninstalled.
In fact, I am using a SynchronousBundleListener to listen to bundle events myself, and if in the listener I try to call EMF.close() I get an IllegalStateException that states that the factory is already closed.
After reinstalling the bundle containing the persistence unit I get the EMF from the builder, but the class descriptors in the MetamodelImpl do not match, i.e. the class objects used as keys of the field "entities" of type Map<Class, EntityTypeImpl<?>> in MetamodelImpl are not the same classes as those included in the reinstalled bundle. The classname is the same, but the hashcode does not match and when I try to use the ne EMF I get the above error.
Is there something special I should do to have EclipseLink reset and recreate the MetamodelImpl object?
Giamma.
[Updated on: Mon, 25 June 2012 07:25] Report message to a moderator
FUDForum. Page generated in 0.02361 seconds
