Home » Eclipse Projects » Eclipse 4 » Ignore CSS for some Widgets
Ignore CSS for some Widgets [message #889729] Tue, 19 June 2012 10:18 Go to next message
Quang Tran is currently offline Quang Tran
we have in our Application some Labels which shows depending on a state the text in green or red (background)
This doesn't harmonise with the CSS Binding in E4, because we set the background before the CSS Databinding is running.
So the text, at first creation, no matter in what state we are, is the default color defined in CSS.
I did a workaround by adding a paint listener to the label.
label.addListener( SWT.Paint, new Listener() {
            public void handleEvent(final Event event) {
                if( isActive ) {
                    label.setBackground( green );
                } else {
                    label.setBackground( red );
But I don't like this solution, is there any other way?
Re: Ignore CSS for some Widgets [message #889803 is a reply to message #889729] Tue, 19 June 2012 13:20 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
Quang Tran wrote on Tue, 19 June 2012 10:18
Could you expand on this, please? Why isn't the CSS theme running?
I can think of a couple of approaches:
1. Ensure the CSS engine is started before you create your GUI. The CSS is applied quickly -- I've never seen any flash from it being applied after the UI has been rendered.
2. Explicitly query the CSS Engine to calculate the CSS property values that are to be applied to your table (see WidgetElement.getCSSEngine() and CSSEngine.getViewCSS()) and use those values to populate the foreground and background.
Brian.
Re: Ignore CSS for some Widgets [message #889906 is a reply to message #889729] Wed, 20 June 2012 04:14 Go to previous messageGo to next message
Here is another example why we need a function to ignore css for some widgets:
If you have a dark css theme and a part of your css file is defined as follows:
.MPartStack.active ExpandBar {
	background-color: #101010;
	color: black;
.MPartStack ExpandBar {
	color: black;
Label {
	font: Verdana 8px;
	color: white;
Composite Label {
	color: white;
And you have a viewpart, which shows the text color of the labels, depending on a state, in red or green. This does not work if your view loose the focus and gain it again later, because the label colors will be white again due to the CSS binding.
Quang
[Updated on: Wed, 20 June 2012 04:15]
Report message to a moderator
Re: Ignore CSS for some Widgets [message #889941 is a reply to message #889906] Wed, 20 June 2012 06:25 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Am 20.06.12 10:14, schrieb Quang Tran:
> widgets:
> follows:
> color: black;
> color: black;
> Label {
> font: Verdana 8px;
> color: white;
> Composite Label {
> color: white;
> loose the focus and gain it again later, because the labels will be in
> Quang
Why are you need creating a CSS-Rule for highlighted labels?
Current-Code:
Label l = ...
l.setForegroundColor(....)
CSS/Java-Code:
Css:
Label.highlight {
color: red;
Java:
IStylingEngine se = ...
Label l = ...
se.setClassname("highlighted");
Tom
Re: Ignore CSS for some Widgets [message #891505 is a reply to message #889729] Mon, 25 June 2012 02:14 Go to previous message
Hi Tom,
What do you mean by that?
Current-Code:
Label l = ...
CSS/Java-Code:
Css:
Label.highlight {
color: red;
Java:
Label l = ...
this seems like a good solution for us, thanks!
Previous Topic:Updating fails 4.2.0 - I20120315-1300 [SOLVED -THANKS]
Next Topic:EModelService findElement()
Current Time: Sun May 19 16:22:05 EDT 2013
Powered by FUDForum. Page generated in 0.01607 seconds
