Home » Eclipse Projects » Jubula » Does Jubula need Server X to perform the test?(Running Jubula on a UNIX environment)
Does Jubula need Server X to perform the test? [message #890569] Fri, 22 June 2012 11:26 Go to next message
Zhongling HANG is currently offline Zhongling HANG
Now I am doing some study about the use of Jubula. I am confused with some problems:
(1) Does Jubula need Server X to perform the test?
(2) If we can run the tests in server mode, how to do it?
(3) Are the test scenarios in Jubula based on EMF? (Because I feel that the test in Jubula is organised like the model EMF)
Thank you very much
Jubula, SWTBot
Re: Does Jubula need Server X to perform the test? [message #890655 is a reply to message #890569] Fri, 22 June 2012 15:19 Go to previous messageGo to next message
Achim Loerke is currently offline Achim Loerke
1 + 2) I have no idea what you mean by "Server X". Please explain.
3) No, Jubula uses JPA with EclipseLink as persistence provider.
- Achim
Re: Does Jubula need Server X to perform the test? [message #891547 is a reply to message #890655] Mon, 25 June 2012 04:17 Go to previous messageGo to next message
Thank you very much for your reponse!
Server X is a system that allows the user to interact with the machine using a graphical interface unlike the famous console and command line. It is found mainly on Linux, Unix and BSD. Is it possible to use Jubula in Unix without Server X? Can we use Jubula just with the command line?
Jubula, SWTBot
Re: Does Jubula need Server X to perform the test? [message #891557 is a reply to message #891547] Mon, 25 June 2012 04:31 Go to previous messageGo to next message
Okay, now i got it. You are talking about the X Window System and its server, right?
With that in mind the answer is quite simple: for all Jubula tests you need some sort of graphical interface. On MS Windows variants this is obviously Windows ;-); on Linux X is supported, OSX doesn't support X (but its on system, Cocoa). Please be aware that on Linux GTK is needed for most operations.
Running the tests on all platforms is no different from running your application on this platforms.
- Achim
Re: Does Jubula need Server X to perform the test? [message #891565 is a reply to message #891557] Mon, 25 June 2012 05:00 Go to previous message
Yes, that is just what I asked. Thank you very much for you answer. Now I am very clear. Thanks a lot!
Jubula, SWTBot
Previous Topic:Using Jubula with multiple test writers
Next Topic:JFileChooser
Current Time: Sat May 18 18:28:21 EDT 2013
Powered by FUDForum. Page generated in 0.01560 seconds
