| users & Roles administration [message #890449] |
Fri, 22 June 2012 06:24  |
reda Mohamed Messages: 2 Registered: June 2012 |
Junior Member |
We are actually doing some tests with Hudson in Capgemini Campany.
We make a test for 2 administrators together in the same time but we have some problems with Roles and users Manager so the result of this test is :
The last administrator click in the save or validate here modification crush all modification of the seconds administrator.
We must use only one Administrator ? there is a way to have a solution in Hudson (users & Roles administration) concurrency management like plugins or modification for this problem.
Best wish
[Updated on: Fri, 22 June 2012 06:53] Report message to a moderator
| Re: users & Roles administration [message #890704 is a reply to message #890449] |
Fri, 22 June 2012 18:01   |
I don't believe there is an option for that. Two admins should be able to override each other.
Think about it like this. If you have one super administrator make a change and leaves the company or forgets their password and can't recover. Then no one would be able to override those changes and someone would manually need to modify the hudson config.xml file directly.
* @author Steven Christou
* @dev Hudson-ci
FUDForum. Page generated in 0.04765 seconds
