Home » Eclipse Projects » Plugin Development Environment (PDE) » build plugin with command line
build plugin with command line [message #889638] Tue, 19 June 2012 08:37 Go to next message
Laurent Extier is currently offline Laurent Extier
Hi All,
I have a plugin source and I would like to build it automatically by the command line.
I don't know how to do that, is there someone that can give me the different steps for that ?
Laurent
Re: build plugin with command line [message #890234 is a reply to message #889638] Thu, 21 June 2012 10:35 Go to previous messageGo to next message
Martin Skorsky is currently offline Martin Skorsky
One way is to use the PDE headless build. See http://www.eclipse.org/articles/Article-PDE-Automation/automation.html or http://www.eclipse.org/pde/pde-build/.
Re: build plugin with command line [message #890240 is a reply to message #889638] Thu, 21 June 2012 11:01 Go to previous messageGo to next message
I have found this document.
Currenttly I have a problem. because I have generated the build.xml by right clicking on my plugin.xml and PDE Tools-> Create Ant Build file.
the default target is build.jars, but when executing this target I have only the classes of the plugin compiled but no jar generated. The target doesn't reference any <jar ant task.
An idea ?
Laurent
Re: build plugin with command line [message #890265 is a reply to message #889638] Thu, 21 June 2012 12:35 Go to previous messageGo to next message
Thanks for your help,
In fact I have generated a build.xml by using PDE Tools -> Generate Ant build file
And when I execute it, it generate only a @dot directory with the classes compiled but not jar plugin.
I don't understand why.
Any idea ?
Laurent
Re: build plugin with command line [message #890409 is a reply to message #890265] Fri, 22 June 2012 04:51 Go to previous message
in http://www.eclipse.org/articles/Article-PDE-Automation/automation.html use section 'Build headless'. To start create the files allElements.xml and build.properties from the templates mentioned in section 'Build phases'.
There is also documentaiton on this at http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.pde.doc.user/tasks/pde_product_build.htm
Previous Topic:Hiding text in Editor
Next Topic:[JADE] A lot of instance of JADE's agent in Eclipse
Current Time: Sat May 25 22:14:20 EDT 2013
Powered by FUDForum. Page generated in 0.04414 seconds
