Home » Eclipse Projects » Sapphire » Problem while exporting a plugin
Problem while exporting a plugin [message #890033] Wed, 20 June 2012 13:20 Go to next message
Etienne Beaumont is currently offline Etienne Beaumont
Hello everybody,
While trying to export my Sapphire plugin, I have the following error poping :
E:\USERS\ebeaumon\workspace\.metadata\.plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container.feature\compile.org.eclipse.pde.container.feature.xml:4: The following error occurred while executing this line:
E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\build.xml:328: The following error occurred while executing this line:
E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\build.xml:245: The following error occurred while executing this line:
E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\customBuildCallbacks.xml:54: The following error occurred while executing this line:
E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\customBuildCallbacks.xml:97: Error running apt.exe compiler
Adding <record name="${basedir}/logapt.txt" action="start"/> only gives me :
   [delete] Deleting directory E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\.apt_generated
    [mkdir] Created dir: E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\.apt_generated
      [jar] Building jar: E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\apt-classpath.jar
   [delete] Deleting: E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\apt-classpath.jar.manifest
   [delete] Deleting: E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\apt-factorypath.jar.manifest
      [apt] E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\customBuildCallbacks.xml:97: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
      [apt] Since compiler setting isn't classic or modern, ignoring fork setting.
      [apt] Compiling 79 source files to E:\USERS\ebeaumon\workspace\SapphireVtXMLEditor\.apt_generated
I also tried to export the sapphire.samples, and had the same error, so I guess it is probably a configuration problem.
(I read the [message #762110] and I have no spaces in my eclipse path)
Do you know what to do to have more information on the apt error?
I tried everything I had in mind but I am far from being an expert in APT...
Thank you very much,
Etienne
[Updated on: Wed, 20 June 2012 13:21]
Report message to a moderator
Re: Problem while exporting a plugin [message #890059 is a reply to message #890033] Wed, 20 June 2012 17:15 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
Etienne,
This issue could be caused by running the Ant script with a JRE as opposed to a JDK install. A JRE install does not contain apt.
The PDE export wizards re-use the JRE/JDK that Eclipse itself is running with when launching the Ant script.
To try to resolve this, edit your eclipse.ini file and add the following two lines at the very beginning:
-vm
[path within a JDK install]\jvm.dll
- Konstantin
Re: Problem while exporting a plugin [message #890192 is a reply to message #890059] Thu, 21 June 2012 08:16 Go to previous message
It worked but failed a little later - probably incompatibilities between Sapphire 0.4 and 0.5, both were installed in a very messy way.
I did a clean install of eclipse (with jdk + Eclipse EE) and the sapphire part works now (I still have problems with exporting the FOP pdf generator).
Thanks for this answer, thanks for your support, and thanks for the project. Smile
Etienne
[Updated on: Thu, 21 June 2012 08:16]
Previous Topic:XML files with missing namespace/schema
Next Topic:Announcing Sapphire 0.5 Release
Current Time: Wed May 22 11:22:39 EDT 2013
Powered by FUDForum. Page generated in 0.02405 seconds
