Home » Modeling » UML2 » Compatibility of applied profiles
Compatibility of applied profiles [message #889936] Wed, 20 June 2012 06:00 Go to next message
Tex Iano is currently offline Tex Iano
Member
I have a UML profile in two versions. An old and a new one. They are mostly identical, also the namespaces are identical.
However, due to the changes, the IDs within the XMI are not identical any more.
My problem is now, that I have an eclipse version with the new UML profile as plug-in. Old models however refer to the old UML profile. I thought this is no problem as the namespace is identical. However, now I have seen that when applying a UML profile also IDs are used to reference the profile and their elements. Here is an excerpt of the head of one of my UML models:
xmlns:Semantics="http://www.myProfile.com/semantics/1.0/Semantics" xsi:schemaLocation="http://www.myProfile.com/semantics/1.0/Semantics pathmap://UML_PROFILES/Semantics.profile.uml#_Oo3pILCVEeGpLMb64seDbg
The idea behind the "Semantics.profile.uml" is identical to the one within the profile. However, the new profile has another ID but it is mostly identical. The old references should be kept.
So, when changing a UML profile the IDs are regenerated and all my models are not usable any longer? Do I have to apply all stereotypes etc. again?
Or is there a good way to convert my model with the old profile applied into a model with the new profile applied?
Tex
Re: Compatibility of applied profiles [message #889947 is a reply to message #889936] Wed, 20 June 2012 06:58 Go to previous messageGo to next message
Similar xmi:id instability has been reported before as a nuisance.
This seems like a bug. Please raise a Bugzilla.
Ed Willink
On 20/06/2012 11:01, Tex Iano wrote:
> any more.
> etc. again?
> Tex
Re: Compatibility of applied profiles [message #889956 is a reply to message #889947] Wed, 20 June 2012 07:55 Go to previous messageGo to next message
Member
Hey Ed,
ok thanks. I will first try to find out the problem.
Tex
Re: Compatibility of applied profiles [message #889981 is a reply to message #889936] Wed, 20 June 2012 09:17 Go to previous message
Peter  is currently offline Peter
Member
All your profile versions are stored under the "UML" EAnnotation.
Therefore you can use all of your models - old and new ones...
Peter
Am 20.06.2012 12:01, schrieb Tex Iano:
> any more.
> etc. again?
> Tex
Previous Topic:How does "isProfileApplied" work?
Next Topic:error using UML as input
Current Time: Tue May 21 11:26:11 EDT 2013
Powered by FUDForum. Page generated in 0.06325 seconds
