Home » Eclipse Projects » GEF » Zest Bug - Small Nodes(No proper redraw of the graph)
Zest Bug - Small Nodes [message #889814] Tue, 19 June 2012 14:18 Go to next message
Ali Beli is currently offline Ali Beli
I'm new to Zest and GUI. For my GUI I'm using JFrames and JButtons and the Graph is shown by Zest. Somehow I'm facing a problem, when trying to redraw my graph.
Here is a simple demo of my problem:
public class shelltest {
	Display d;
	public void showGUI(){
		JFrame frame= new JFrame("SWT GUI");
		frame.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
		JPanel buttonPanel = new JPanel(new GridLayout(2,3));
		final JButton createButton = new JButton("Create Graph");
		buttonPanel.add(createButton);
		frame.getContentPane().add(buttonPanel);
		createButton.setEnabled(true);
		ActionListener createListener = new ActionListener() {
			public void actionPerformed(ActionEvent e) {
				showGraph();
		createButton.addActionListener(createListener);
		frame.setVisible(true);
	public void showGraph(){
		new Thread() {
		public void run() {
            		d = new Display();
        		Shell shell = new Shell(d);
        		shell.setText("Test");
        		shell.setLayout(new FillLayout());
        		Graph g = new Graph(shell, SWT.NONE);
        		GraphNode a = new GraphNode(g,ZestStyles.NODES_CACHE_LABEL, "A");
        		new GraphConnection(g,SWT.NONE,a,new GraphNode(g,SWT.NONE, "B"));
        		g.setLayoutAlgorithm(new SpringLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING), true);
        		shell.open();
        		while (!shell.isDisposed()) {
        		   if (!d.readAndDispatch()) {
        	           	d.sleep();
        	    a.dispose();
        		g.clear();
        		g.dispose();
        		d.dispose();
      	  }.start();
		shelltest myshell = new shelltest();
		myshell.showGUI();
If I press the "Create Graph"-Button, the Shell opens and shows me the Graph. Somehow, if I close this new opened window and again press the "Create-Graph"-Button, the graph is shown in a inproper way, with tiny nodes and unreadable labels. Can anyone tell me, how to fix this?
Thank you
Re: Zest Bug - Small Nodes [message #889826 is a reply to message #889814] Tue, 19 June 2012 15:38 Go to previous messageGo to next message
Jan Krakora is currently offline Jan Krakora
Interesting. If you don't recreate the display, but use always the same instance it works fine.
But why is that, I really don't know.
Re: Zest Bug - Small Nodes [message #889832 is a reply to message #889814] Tue, 19 June 2012 16:21 Go to previous messageGo to next message
Thanks for your reply. How do you use just one instance of the display?
If I instantiate the display d only once, I'm getting an invalid thread access exception.
Re: Zest Bug - Small Nodes [message #889872 is a reply to message #889832] Wed, 20 June 2012 01:55 Go to previous message
import java.awt.GridLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JPanel;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.zest.core.widgets.Graph;
import org.eclipse.zest.core.widgets.GraphConnection;
import org.eclipse.zest.core.widgets.GraphNode;
import org.eclipse.zest.core.widgets.ZestStyles;
import org.eclipse.zest.layouts.LayoutStyles;
import org.eclipse.zest.layouts.algorithms.SpringLayoutAlgorithm;
	final Display d;
	volatile boolean closed;
	public shelltest(Display d) {
		this.d = d;
	public void showGUI() {
		frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		frame.addWindowListener(new WindowAdapter() {
			public void windowClosed(WindowEvent e) {
				closed = true;
				showGraph();
		d.asyncExec(new Runnable() {
			public void run() {
				shell.open();
		Display d = new Display();
		shelltest myshell = new shelltest(d);
		myshell.showGUI();
		while (!myshell.closed) {
				d.sleep();
		d.dispose();
[Updated on: Wed, 20 June 2012 02:51]
Report message to a moderator
Previous Topic:Best way to add Draw2d to a GraphicalEditorWithFlyoutPalette?
Next Topic:Integrate tree drawing algorithm in GEF editor?
Current Time: Thu May 23 17:11:36 EDT 2013
Powered by FUDForum. Page generated in 0.03525 seconds
