Home » Eclipse Projects » scout » Widget showcase
Widget showcase [message #889802] Tue, 19 June 2012 13:17 Go to next message
Boy D'Poy is currently offline Boy D'Poy
Hi!
As scout developement is client oriented (maybe GUI oriented) won't it be suitable for us (newbees) to hawe a widget showcase with little snipets as a startpoint?
4 instance, what class should I use to build a combobox and if possible how? (I don't see anywhere an AbstractComboboxField or somthing like ;( )
Thanks.
Re: Widget showcase [message #889809 is a reply to message #889802] Tue, 19 June 2012 13:52 Go to previous messageGo to next message
Arthur vD is currently offline Arthur vD
Member
A widget showcase would certainly be a good idea.
A Scout SmartField resembles a combobox. The available choices are supplied by a CodeType or a LookupCall. See the links below:
SmartField wiki page: wiki.eclipse.org/Scout/Concepts/SmartField
MiniCrm tutorial chapter regarding CodeTypes: wiki.eclipse.org/Scout/Tutorial/3.8/Minicrm/Code_Types
Service wiki page:wiki.eclipse.org/Scout/Concepts/Lookup_Service
Tutorial Chapter about LookupCalls: wiki.eclipse.org/Scout/Tutorial/Lookup_Calls
Sorry about the non clickable links. I'm not yet allowed to post links. Sad
If anything is unclear please feel free to ask.
Arthur
Re: Widget showcase [message #889813 is a reply to message #889809] Tue, 19 June 2012 14:07 Go to previous messageGo to next message
Member
Something like a widget showcase is being created here:
wiki.eclipse.org/Scout/Concepts/Field
[Updated on: Tue, 19 June 2012 14:09]
Report message to a moderator
Re: Widget showcase [message #890320 is a reply to message #889813] Thu, 21 June 2012 18:35 Go to previous messageGo to next message
ok, thank you!
Re: Widget showcase [message #890339 is a reply to message #889813] Fri, 22 June 2012 01:32 Go to previous message
Jeremie Bresson is currently offline Jeremie Bresson
To my mind, the scout fields page is still work in progress.
Feel free to tell us what we could improve.
Previous Topic:Provide Service Config Properties from Plug-in
Next Topic:radiobuttongroup in searchform
Current Time: Tue May 21 06:28:39 EDT 2013
Powered by FUDForum. Page generated in 0.01828 seconds
