Home » Eclipse Projects » Remote Application Platform (RAP) » Resorting ot editors (After closing of one tab the tabs of remaining editors will be resorted)
Resorting ot editors [message #888755] Mon, 18 June 2012 11:30 Go to next message
Waldemar Cichon is currently offline Waldemar Cichon
If I open 3 or more editors in my app, and then close one of them, the editor tabs of the remaining editors are resorted.
What to do, I need, that the order remains the same.
Waldemar
Re: Resorting ot editors [message #889526 is a reply to message #888755] Tue, 19 June 2012 06:11 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf Sternberg
Hi Waldemar,
I don't know the answer - but have you tried your application with RCP?
RAP should behave no different than RCP, so I guess it's not directly a
RAP question and you may have more success on another forum.
If you cannot reproduce the behavior with RCP, you can create a minimal
application to reproduce the problem and open a bug against RAP [1].
Regards, Ralf
[1] http://eclipse.org/rap/bugs/
Ralf Sternberg
Twitter: @EclipseRAP
Re: Resorting ot editors [message #889602 is a reply to message #888755] Tue, 19 June 2012 07:51 Go to previous message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
are you using RAP business design? There was a problem:
333080: [design] Wrong view order after closing a view
https://bugs.eclipse.org/bugs/show_bug.cgi?id=333080
but it is fixed in 1.4. Which RAP version are you using?
Best,
Ivan
> editor tabs of the remaining editors are resorted. What to do, I need,
> Regards
> Waldemar
Ivan Furnadjiev
Previous Topic:Context Sensitive Help in RAP
Next Topic:The alias '/rwt-resources' is already in use.
Current Time: Sat May 25 22:42:18 EDT 2013
Powered by FUDForum. Page generated in 0.01569 seconds
