| EclipseLink can't login on startup project in Eclipse [solved] [message #888783] |
Mon, 18 June 2012 12:04  |
Jhonathan Corrêa Messages: 2 Registered: June 2012 |
Junior Member |
Until last windows update, my application worked fine, but after that, I tried to connect to database, but Eclipse "freezes" (through Eclipse, on project properties -> JPA -> Connection -> Connect) and to deploy that on Tomcat (through Eclipse too), after startup, the application halts with an Eclipse Message: "Server Tomcat v7.0 Server at localhost was unable to start within 45 seconds. If the server requires more time, try increasing the timeout in the server editor.". But the problem isn't the tomcat, cause I do a deploy directly on it, and worked. I also try to change eclipse and Tomcat diretories but without success. I also tried to increases Tomcat time, but it didn't work. Does somebody knows whats going wrong with this? I'm sure that the problem is the OS, cause on Ubuntu it's working, but, is there some workaround or another solution to run it on Windows too?
[Updated on: Mon, 18 June 2012 13:19] Report message to a moderator
FUDForum. Page generated in 0.02285 seconds
