Home » Modeling » GMF (Graphical Modeling Framework) » GMF Codegen 2.9 - API breakage?
GMF Codegen 2.9 - API breakage? [message #888819] Mon, 18 June 2012 17:05 Go to next message
Martin Fluegge is currently offline Martin FlueggeFriend
we (CDO/Dawn) recently updated our baseline and found the one of our
bundle now show API errors which did not appear the last time. After
digging around we found out that our baseline now contains gmf.codegen
2.9 indead of version 2.2.
While we are re-expoting the tooling bundles we are also effected by the
changes. The problem is that although the versions only change in the
minor segment it seems that GMF tooling made a major version jump
because some classes have been deleted or removed from the API (see
traces below). Is this intentional or did this happen by mistake?
Thanks in advance.
Martin
Traces
Description Resource Path Location Type
The re-exported type
org.eclipse.gmf.codegen.gmfgen.provider.GenTemplateInvocationItemProvider has
been removed from
org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.edit_2.0.0 MANIFEST.MF
/org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.edit/META-INF line 1
Compatibility Problem
org.eclipse.gmf.codegen.gmfgen.provider.GenVisualEffectItemProvider has
been removed from
org.eclipse.gmf.codegen.gmfgen.provider.OclChoiceParserItemProvider has
been removed from
org.eclipse.gmf.codegen.gmfgen.provider.PredefinedEnumParserItemProvider
has been removed from
The major version should be incremented in version 2.0.0, since API
breakage occurred since version 2.0.0 MANIFEST.MF
/org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.edit/META-INF line 5
Version Numbering Problem
The re-exported type org.eclipse.gmf.codegen.gmfgen.OclChoiceParser has
been removed from
The re-exported type org.eclipse.gmf.codegen.gmfgen.GenVisualEffect has
been removed from
org.eclipse.gmf.codegen.gmfgen.GenTemplateInvocationBase has been
removed from org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.edit_2.0.0
MANIFEST.MF /org.eclipse.emf.cdo.dawn.codegen.dawngenmodel.edit/META-INF
line 1 Compatibility Problem
org.eclipse.gmf.codegen.gmfgen.GenTemplateInvocation has been removed
org.eclipse.gmf.codegen.gmfgen.provider.GenTemplateInvocationBaseItemProvider
org.eclipse.gmf.codegen.gmfgen.provider.GenFixedInputsTemplateInvocationItemProvider
org.eclipse.gmf.codegen.gmfgen.provider.GenCustomGeneratorExtensionItemProvider
The re-exported type org.eclipse.gmf.codegen.gmfgen.PredefinedEnumParser
org.eclipse.gmf.codegen.gmfgen.GenFixedInputsTemplateInvocation has been
org.eclipse.gmf.codegen.gmfgen.GenCustomTemplateInput has been removed
org.eclipse.gmf.codegen.gmfgen.GenCustomGeneratorExtension has been
Re: GMF Codegen 2.9 - API breakage? [message #889621 is a reply to message #888819] Tue, 19 June 2012 12:17 Go to previous messageGo to next message
Michael Golubev is currently offline Michael GolubevFriend
This classes indeed had been _added_ in 2.9 for Juno.
There were neither removed classes nor changes that may break binary backward compatibility.
To my understanding the problem is that added API classes don't have @since 2.9 javadoc.
Michael
Re: GMF Codegen 2.9 - API breakage? [message #889944 is a reply to message #889621] Wed, 20 June 2012 10:48 Go to previous message
Hi Michael,
thanks for the quick response. If no classes have been removed, we can
ignore the warnings.
Martin
Am 19.06.2012 14:17, schrieb Michael Golubev:
> Hello,
> This classes indeed had been _added_ in 2.9 for Juno. There were neither
> @since 2.9 javadoc.
> Regards, Michael
Previous Topic:How to arrange the property
Next Topic:Customize property view
Current Time: Sat Jul 22 09:21:45 GMT 2017
Powered by FUDForum. Page generated in 0.04617 seconds
