Home » Eclipse Projects » Jubula » Adding language support to reused projects (unbound_modules_concrete / _rcp / _swt).(Does anyone know how this can be done?)
Adding language support to reused projects (unbound_modules_concrete / _rcp / _swt). [message #775595] Fri, 06 January 2012 05:27 Go to next message
Lars-Remi Pettersen is currently offline Lars-Remi Pettersen
Hey there,
We've recently started looking at jubula for testing the gui parts of our rcp applications, but we're running into some (hopefully) minor startup issues. After defining a project and an AUT with norwegian language default, we get the following errors:
Reused Project "unbound_modules_concrete" does not support language "Norwegian (Norway)". Either add language "Norwegian (Norway)" to "unbound_modules_concrete" or remove language "Norwegian (Norway)" from the current Project.
Reused Project "unbound_modules_rcp" does not support language "Norwegian (Norway)". Either add language "Norwegian (Norway)" to "unbound_modules_rcp" or remove language "Norwegian (Norway)" from the current Project.
Reused Project "unbound_modules_swt" does not support language "Norwegian (Norway)". Either add language "Norwegian (Norway)" to "unbound_modules_swt" or remove language "Norwegian (Norway)" from the current Project.
The first thing I tried upon observing this was changing the language to english. That removed the errors, but the AUT refused to start, as the RCP application does not have defined properties for most of its resources in the english locale (it's a purely norwegian locale application).
So my question is as follows: How can I add the norwegian language to these reused projects? I've looked around, but I can't really find where they're located, neither in eclipse nor on the file system. I also tried both googling and searching these forums, without luck. Hopefully someone in here can help me out. Thanks in advance! Smile
Re: Adding language support to reused projects (unbound_modules_concrete / _rcp / _swt). [message #780470 is a reply to message #775595] Wed, 18 January 2012 02:53 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
The unbound modules are currently only available for a certain set of languages - it's also currently not easy to add new language data everywhere (even if you did it by hand, it would be gone with the next version). I spoke to one of the developers though, and they said that starting the AUT in English should work: when it finds no resources for English, it should resort to the default (in this case, Norwegian).
Hope this helps a bit!
Alex
Re: Adding language support to reused projects (unbound_modules_concrete / _rcp / _swt). [message #888402 is a reply to message #780470] Mon, 18 June 2012 00:44 Go to previous messageGo to next message
Anu J is currently offline Anu J
Hi Alex,
Could you post a link which contains a list of languages supported by the unbound modules?
Re: Adding language support to reused projects (unbound_modules_concrete / _rcp / _swt). [message #888516 is a reply to message #888402] Mon, 18 June 2012 04:19 Go to previous message
The attached image shows the language list in the unbound modules.
index.php/fa/10325/0/
HTH,
Alex
Previous Topic:Object Mapping : same component twice
Next Topic:Is there solution for the composites unknown?
Current Time: Sat May 18 14:45:22 EDT 2013
Powered by FUDForum. Page generated in 0.11389 seconds
