| Object Mapping : same component twice [message #888340] |
Sun, 17 June 2012 22:24  |
Anu J Messages: 18 Registered: June 2012 |
Junior Member |
I would like to know if it is possible to map the same object twice?
Assuming there are two ways I can display a particular pop up, then assume I have a button on the pop up, when I try mapping the button for the second time, it shows the previous mapping.
So if I assign 2 values to the "Assigned Names" , should it work correctly or is there any existing issue?
Because right now it is not considering the second mapping.
Thanks.
[Updated on: Sun, 17 June 2012 22:25] Report message to a moderator
FUDForum. Page generated in 0.12169 seconds
