Home » Eclipse Projects » Marketplace Client Project » problem to connetc to marketplace on indivo realese 2
problem to connetc to marketplace on indivo realese 2 [message #887020] Fri, 15 June 2012 20:41 Go to next message
peppe scuglia is currently offline peppe scuglia
Hello, i've a problem to connect my eclipse indigo release 2 JEE with marketplace to download the jboss tools...
LOG
java.lang.reflect.InvocationTargetException
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
	at org.eclipse.equinox.internal.p2.ui.discovery.wizards.CatalogViewer.updateCatalog(CatalogViewer.java:563)
	at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.updateCatalog(MarketplaceViewer.java:453)
	at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage$6.run(MarketplacePage.java:332)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand.execute(MarketplaceWizardCommand.java:171)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.IllegalStateException
	at org.eclipse.equinox.internal.p2.discovery.Catalog.performDiscovery(Catalog.java:64)
	at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.performDiscovery(MarketplaceCatalog.java:255)
	at org.eclipse.equinox.internal.p2.ui.discovery.wizards.CatalogViewer$6.run(CatalogViewer.java:569)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
THE LOG:
Code: [Select all] [Show/ hide]
Solutions?
Everytimes i go to marketplace or ceck updates or installa new software there is the same problem, the connection Unable to read repository
Re: problem to connetc to marketplace on indivo realese 2 [message #887459 is a reply to message #887020] Sat, 16 June 2012 13:05 Go to previous messageGo to next message
please help!!
Re: problem to connetc to marketplace on indivo realese 2 [message #889642 is a reply to message #887459] Tue, 19 June 2012 08:41 Go to previous messageGo to next message
plaese some solutions, i don't know what i have to do
Re: problem to connetc to marketplace on indivo realese 2 [message #889829 is a reply to message #887020] Tue, 19 June 2012 16:15 Go to previous messageGo to next message
Ian Skerrett is currently offline Ian Skerrett
What version of the JBoss tools are you trying to install? It needs to be the Indigo version and not the Helios version.
Re: problem to connetc to marketplace on indivo realese 2 [message #890028 is a reply to message #889829] Wed, 20 June 2012 12:29 Go to previous messageGo to next message
thanks for help!!
I install indigo Realese 2 JEE the last version, that i think want jboss 3.2.
But i don't know to understand why the connectin between eclipse indigo JEE to marketplace doesn't work.
Other thing if i try to enter in marketplace with the other eclipse that i've installated before now, there is always the same error.
Maybe there is a conflict between the different version of eclipse?
There is always this error and other:
Address family not supported by protocol family: connect
Please help me
thanks
Re: problem to connetc to marketplace on indivo realese 2 [message #890049 is a reply to message #890028] Wed, 20 June 2012 15:45 Go to previous messageGo to next message
Tom Seidel is currently offline Tom Seidel
Member
Based on the given stacktrace it indicates a misconfiguration of your eclipse installation. Could you please try to install the solution from the marketplace with a fresh install of Eclipse?
Cheers
Tom
Re: problem to connetc to marketplace on indivo realese 2 [message #890926 is a reply to message #890049] Sat, 23 June 2012 09:13 Go to previous message
thanks for help
i try to install another version but it's the same!!
Previous Topic:How do I test install for my project via Marketplace Client?
Next Topic:Filtering entries based on Eclipse platform version
Current Time: Thu May 23 00:10:16 EDT 2013
Powered by FUDForum. Page generated in 0.01943 seconds
