Home » Modeling » UML2 Tools » Installation Problems
Installation Problems [message #886596] Fri, 15 June 2012 04:49 Go to next message
zeuge jehova is currently offline zeuge jehova
i have installed uml2 tools sdk successfully but i cant see the list entry "uml 2.1 diagrams" in the new > other dialog.
my environment is:
+ fedora 17 64 bit (linux 3.4)
+ manually downloaded and extracted eclipse cdt Indigo Service Release 2 Build id: 20120216-1857
i installed the uml2 tools sdk this way, I ...
1. have enabled about any update sites available in the update sites dialog
2. disabled those that do not work
3. opened the update site http_//www_eclipse_org/modeling/updates/releases with the "install new software" dialog (i replaced . with _ because of forum restrictions)
4. checked mdt uml2tools sdk (incubation) 0.9.0
5. followed the instructions
6. restarted eclipse
then i tried to create a uml diagram with the graphical editor and faced the problem i mentioned above.
where is my mistake?
kind reagards
zeuge jehova
ps: (i have searched this problem, but its hard to describe so i didn't find anything except one thread on this forum where a guy just reinstalled the uml2 tools, but that didn't work for me -.-)
[Updated on: Fri, 15 June 2012 04:50]
Report message to a moderator
Re: Installation Problems [message #886650 is a reply to message #886596] Fri, 15 June 2012 07:10 Go to previous message
You have to use the 0.10.0 I-build from
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2tools for Indigo.
Juno adds support for UML 2.4 and 2.4.1 and as a result MDT/UML moves
from 3.x to 4.x, which makes use of UML2Tools builds incompatible.
It does not look like there will be a Juno build of UML2Tools, so I
suggest you switch to MDT/Papyrus.
Ed Willink
On 15/06/2012 09:49, zeuge jehova wrote:
> Hello,
> my environment is:
> i installed it this way, I ...
> dialog
> kind reagards
> zeuge jehova
Previous Topic:Unable to load UML model in stand alone application
Next Topic:[SOLVED] Failed to add a node in Activity diagram in a standalone application
Current Time: Tue May 28 18:05:05 EDT 2013
Powered by FUDForum. Page generated in 0.01511 seconds
