Home » Modeling » UML2 » href="http://schema.omg.org/spec/UML/2.1/uml.xml#Integer"/> to EInt
href="http://schema.omg.org/spec/UML/2.1/uml.xml#Integer"/> to EInt [message #886426] Thu, 14 June 2012 18:40 Go to next message
max power is currently offline max power
Hi all!
I have an xmi file with an uml class diagram.
Some attributes have following types:
<type xmi:type="uml:PrimitiveType" href="http:||schema.omg.org/spec/UML/2.1/uml.xml#Integer"/>
After the import these attributes have the type PrimitiveTypeImpl.
ToString of the variable "type" returns:
org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@6d23f66c (eProxyURI: http:||schema.omg.org/spec/UML/2.1/uml.xml#Integer)
When I programmatically convert the uml model to ecore, the attributes have the type: EDataTypeImpl.
BUT: when I import the xmi file into an EMF Project via UI the resulting model contains attributes with type EInt. This is what I want to do programmatically, too.
I am using following code for import and conversion to ecore:
ResourceSet resourceSet = new ResourceSetImpl();
Registry packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put("http:||schema.omg.org/spec/XMI/2.1", UMLPackage.eINSTANCE);
packageRegistry.put("http:||schema.omg.org/spec/UML/2.1", UMLPackage.eINSTANCE);
Map<String, Object> extensionToFactoryMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
extensionToFactoryMap.put(XMI2UMLResource.FILE_EXTENSION, new UMLResourceFactoryImpl());
resourceSet.getLoadOptions().put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
URI uri = URI.createURI("model.xmi");
Package root = UML2Util.load(resourceSet, uri, UMLPackage.Literals.PACKAGE);
Set<EPackage> result = Sets.newHashSet();
result.addAll(UMLUtil.convertToEcore(root, null));
Am I doing something wrong?
Re: href=&quot;http://schema.omg.org/spec/UML/2.1/uml.xml#Integer&quot;/&gt; to EInt [message #886647 is a reply to message #886426] Fri, 15 June 2012 07:03 Go to previous message
Yes. Your ability to workaround the misleading MDT/UML2 documentation is
indequate.
Loading a UML resource is a non-trivial activity, since there is support
for more than one UML namespace (version) and you must register the
appropriate content types to ensure that the appropriate resources and
converters are used. You also need to define path-map URI mappings for
profiles.
I have just added a "load" step to the canned solution to
http://wiki.eclipse.org/MDT/UML2/Getting_Started_with_UML2. You may find
it as https://bugs.eclipse.org/bugs/attachment.cgi?id=217415 to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=382342.
Apologies for difficulties.
Ed Willink
Previous Topic:how to load int generals from Integer
Next Topic:UML2 Tools and Indigo
Current Time: Sat May 18 19:52:57 EDT 2013
Powered by FUDForum. Page generated in 0.03066 seconds
