| Delete(org.eclipse.ui.edit.delete) Cool Bar Icon disabled for View [message #885663] |
Wed, 13 June 2012 08:13 |
ModelGeek Mising name Messages: 351 Registered: June 2011 |
I am working on a RCP application using GEF. I have created editor. In my project i need to have a tree which shows the entire model as there can be many editors showing only subset of model.
Problem is when something is selected on Editor or in OutLine page, delete icon is available in toolbar but when i select the same object in this whole model tree then delete icon is not enabled.
One more question, i want to provide delete facility in this whole model tree(as may be there is no editor opened and user want to only use this tree), in this situation i would also like to have undo redo functionality.
Note : undo redo is working fine when i have focus in editor and i do not want outline as it just shows the items present in the currently focused editor. I want to show entire model.
Any Idea?
FUDForum. Page generated in 0.01480 seconds
