| NoSuchMethodError while trying to get Resource [message #882659] |
Wed, 06 June 2012 19:43  |
max power Messages: 9 Registered: May 2012 |
Junior Member |
I try to import an xmi file with uml classes inside.
The file:
<uml:Package xmi:version="2.1" xmlns:xmi="http:||schema.omg.org/spec/XMI/2.1" xmlns:uml="http:||www.eclipse.org/uml2/3.0.0/UML" xmi:id="_OhYn4KZfEeGHZNv_aIvRtQ">
<packagedElement xmi:type="uml:Class" xmi:id="_TKSFoKZfEeGHZNv_aIvRtQ" name="ClassA">
<ownedAttribute xmi:id="_cPGVEKZfEeGHZNv_aIvRtQ" name="surname"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_ZDn3kKZfEeGHZNv_aIvRtQ" name="ClassB">
<ownedAttribute xmi:id="_jD3NcKZfEeGHZNv_aIvRtQ" name="age"/>
</packagedElement>
</uml:Package>
I use following code:
ResourceSet resourceSet = new ResourceSetImpl();
Registry packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put("http:||schema.omg.org/spec/XMI/2.1", UMLPackage.eINSTANCE);
packageRegistry.put("http:||schema.omg.org/spec/UML/2.1", UMLPackage.eINSTANCE);
Map<String, Object> extensionToFactoryMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
extensionToFactoryMap.put(XMI2UMLResource.FILE_EXTENSION, new XMIResourceFactoryImpl());
resourceSet.getLoadOptions().put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
I have tried several ways of getting the resource:
Resource resource = resourceSet.createResource(uri);
resource.load(file.getInputStream(), null);
or this
Resource resource = resourceSet.getResource(uri, true);
and finally this:
Package root = UML2Util.load(resourceSet, uri, UMLPackage.Literals.PACKAGE);
While getting the resource I always get following exception:
java.lang.NoSuchMethodError: org.eclipse.uml2.uml.internal.impl.ElementImpl.eBasicAdapterArray()[Lorg/eclipse/emf/common/notify/Adapter;
at org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotify(ElementImpl.java:964)
at org.eclipse.uml2.uml.internal.impl.NamedElementImpl.setName(NamedElementImpl.java:268)
at org.eclipse.uml2.uml.internal.impl.ClassImpl.eSet(ClassImpl.java:1563)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1154)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2643)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2702)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:85)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2178)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2081)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2016)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:131)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1799)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:167)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1445)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1241)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at de.infoasset.xmiModelImport.XMImodelImport.importXMImodel(XMImodelImport.java:36)
at de.infoasset.emf2hybridWiki.handler.SubmitHandler.importXMImodel(SubmitHandler.java:329)
at de.infoasset.emf2hybridWiki.handler.SubmitHandler.doBusinessLogic(SubmitHandler.java:100)
at de.infoasset.platform.handler.Handler.doDoDoBusinessLogic(Handler.java:195)
at de.infoasset.platform.handler.Handler.doDoBusinessLogic(Handler.java:214)
at de.infoasset.platform.handler.Handler.handleRequestGetStation(Handler.java:173)
at de.infoasset.platform.handler.Handler.handleRequest(Handler.java:115)
at de.infoasset.platform.handler.Handler.getResponse(Handler.java:101)
at de.infoasset.platform.client.RequestDispatcher.handleRequest(RequestDispatcher.java:73)
at de.infoasset.platform.server.WebServer$1.handle(WebServer.java:209)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:973)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:194)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:907)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at de.infoasset.platform.server.WebServer$3.handle(WebServer.java:294)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:47)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:110)
at org.eclipse.jetty.server.Server.handle(Server.java:346)
at org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:442)
at org.eclipse.jetty.server.HttpConnection$RequestHandler.content(HttpConnection.java:941)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:801)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:224)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:51)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:586)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:44)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:598)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:533)
at java.lang.Thread.run(Unknown Source)
I've been trying to implement the import for two weeks now. Need help!
Many thanks in advance!
| Re: NoSuchMethodError while trying to get Resource [message #882781 is a reply to message #882659] |
Thu, 07 June 2012 03:30   |
Ed Merks Messages: 24570 Registered: July 2009 |
Max,
You're using an older EMF library/jar with a newer UML.
> The file:
> name="ClassA">
> </packagedElement>
> name="ClassB">
> </packagedElement>
> </uml:Package>
> Boolean.TRUE);
> or this
> and finally this:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.02006 seconds
