Home » Eclipse Projects » DTP » "NLS missing" messages on Ubuntu
"NLS missing" messages on Ubuntu [message #533350] Thu, 13 May 2010 09:41 Go to next message
Bryn Ellis is currently offline Bryn Ellis
I've just installed Eclipse on my Ubuntu 10.04 workstation along with the eclipse-dtp.
I run a simple select * from table and get nothing returned but the same error as you guys are getting:
NLS missing message: StatusLogger_no_bundle_1 in: org.eclipse.datatools.sqltools.result.PluginResourcesResultH istoryLuceneIndex_io_error ".
I also get this error:
ResultHistoryLuceneIndex_io_errorNLS missing message: StatusLogger_possible_args_1 in: org.eclipse.datatools.sqltools.result.PluginResources
org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out: org.apache.lucene.store.SingleInstanceLock@2d0e1c: write.lock
at org.apache.lucene.store.Lock.obtain(Lock.java:85)
at org.apache.lucene.index.IndexWriter.init(IndexWriter.java:15 50)
at org.apache.lucene.index.IndexWriter.<init>(IndexWriter.java:1107)
at org.eclipse.datatools.sqltools.result.internal.index.ResultH istoryLuceneIndex.addResults(ResultHistoryLuceneIndex.java:1 12)
at org.eclipse.datatools.sqltools.result.internal.index.ResultH istoryLuceneIndex.addResult(ResultHistoryLuceneIndex.java:84 )
at org.eclipse.datatools.sqltools.result.internal.index.History IndexListener.resultInstanceStatusUpdated(HistoryIndexListen er.java:53)
at org.eclipse.datatools.sqltools.result.ResultManager.fireStat usUpdated(ResultManager.java:135)
at org.eclipse.datatools.sqltools.result.internal.model.ResultI nstance.updateStatus(ResultInstance.java:244)
at org.eclipse.datatools.sqltools.result.ResultsViewAPI.updateS tatus(ResultsViewAPI.java:563)
at org.eclipse.datatools.sqltools.editor.core.result.ResultSupp ortRunnable.handleSuccess(ResultSupportRunnable.java:422)
at org.eclipse.datatools.sqltools.editor.core.result.ResultSupp ortRunnable$HandleSuccessJob.run(ResultSupportRunnable.java: 302)
Does anyone have any ideas why I'm getting this please?
Interestingly I've just installed on my Windows 7 workstation as well and I'm getting the same problem. Crying or Very Sad
Bryn
Re: "NLS missing" messages on Ubuntu [message #884364 is a reply to message #533350] Sun, 10 June 2012 19:17 Go to previous message
Rix --- is currently offline Rix ---
I am facing the same issue any work arounds i am unable to relaize the main cause
below part of error, any help will be great and appreciated
eclipse.buildId=unknown
java.version=1.6.0_22
Framework arguments: -product test-client.product
Command-line arguments: -product test-client.product -data E:\Accounts\workspaces\default\eclipse_workspace/../runtime-test-client-prd.product -dev file:E:/Accounts/workspaces/default/eclipse_workspace/.metadata/.plugins/org.eclipse.pde.core/test-client-prd.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 2 0 2012-06-11 01:02:39.551
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-06-11 01:02:39.551
!MESSAGE Commands should really have a category: plug-in='test-client', id='in='test.application.command.ping', categoryId='test.category.tax'
!ENTRY org.eclipse.osgi 2 1 2012-06-11 01:02:41.206
!MESSAGE NLS missing message: startdatein: cm.test.application.Messages
!MESSAGE NLS missing message: enddatein: cm.test.application.Messages
!ENTRY org.eclipse.osgi 2 1 2012-06-11 01:02:41.862
!MESSAGE NLS missing message: authorErrorTitle in: cm.test.application.Messages
Previous Topic:Accessing Result columns after parsing using SQLQueryParser
Next Topic:JPA + Hibernate + Sybase ASE
Current Time: Wed May 29 04:35:58 EDT 2013
Powered by FUDForum. Page generated in 0.01542 seconds
