Home » Eclipse Projects » GEF » Is .clear() no longer supported?
Is .clear() no longer supported? [message #884142] Sun, 10 June 2012 03:59 Go to next message
Hassan M. is currently offline Hassan M.
I've just downloaded the current version of Zest. One of the JAR files is called org.eclipse.zest.core_1.3.0.v20110221-2050.jar. So, my code uses a clear() method for clearing all the elements in a graph, like this:
wbsGraph = new Graph(this,SWT.NONE);
wbsGraph.clear();
But this doesn't work anymore. Was this method removed from the current version? Is there another way of doing this?
Re: Is .clear() no longer supported? [message #884293 is a reply to message #884142] Sun, 10 June 2012 14:35 Go to previous messageGo to next message
Fabian Steeg is currently offline Fabian Steeg
Member
I don't think this was ever supported in Zest 1.x - I remember adding it to Zest 2.x though:
http://git.eclipse.org/c/gef/org.eclipse.zest.git/commit/?id=3a37e2f51dc355a30642682defd99d14111cc9f7
It should work with the latest version of Zest 2, which is available from the Eclipse Marketplace.
Re: Is .clear() no longer supported? [message #884356 is a reply to message #884293] Sun, 10 June 2012 18:39 Go to previous message
Okay, well that wasn't there. I got the sources and added that function (to Graph.java), and that seemed to work. However, I don't know what subGraphFigures are, but that part wasn't working so I just commented it out:
public void clear() {
	for (Iterator i = new ArrayList(connections).iterator(); i.hasNext();) {
		removeConnection((GraphConnection) i.next());
	//for (Iterator i = new HashSet(subgraphFigures).iterator(); i.hasNext();) {
		//removeSubgraphFigure((IFigure) i.next());
	for (Iterator i = new ArrayList(nodes).iterator(); i.hasNext();) {
		removeNode((GraphNode) i.next());
Anyway, thanks for the help!
[Updated on: Sun, 10 June 2012 18:40]
Report message to a moderator
Previous Topic:Undo/Redo Buttons stay disabled
Next Topic:Two OutLine Trees
Current Time: Sat May 25 01:11:15 EDT 2013
Powered by FUDForum. Page generated in 0.01563 seconds
