| RCP actions not observed [message #883840] |
Sat, 09 June 2012 11:00  |
Timothy Vogel Messages: 56 Registered: July 2009 |
Member |
AUT - RCP application
Jubula version 1.2.0
When I observe the AUT, Jubula does not record the following actions:
close an open editor using the x on the editor title tab
select an item from a table that is in a view
Is this my mis-configuration or an issue with Jubula?
Update:
Sometimes Jubula records the close open editor and sometimes it doesn't. Are there known issues with timing or having to wait between actions when using the observation mode?
[Updated on: Sun, 10 June 2012 07:06] Report message to a moderator
| Re: RCP actions not observed [message #884818 is a reply to message #884470] |
Mon, 11 June 2012 18:30  |
Member |
Thanks for your helpful reply!
I will use the menu for closing. Also figured out how to work with a table from manually adding a step instead of recording.
The cheat sheets are nice. They should be much more publicized on the web site and in the docs. I missed them completely and struggled with some of the steps that are in them.
FUDForum. Page generated in 0.03926 seconds
