Home » Eclipse Projects » Eclipse Platform » Config file of CVS Repository(Config file of CVS Repository)
Config file of CVS Repository [message #882810] Thu, 07 June 2012 04:50 Go to next message
Arpit Tripathi is currently offline Arpit Tripathi
Hello All,
I also want to add cvs repository to eclipse but silently. Is there any configuration file where eclipse store the details of cvs server & credentials and reading them from that file to create connection.
Re: Config file of CVS Repository [message #882854 is a reply to message #882810] Thu, 07 June 2012 06:25 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 07.06.2012 10:50, Arpit Tripathi wrote:
> Hello All,
Look at the preference file that gets written when you export your
current CVS repositories (File > Export > General > Preferences). You
should then be able to use that info in the pluginCustomization file.
Dani
Re: Config file of CVS Repository [message #882903 is a reply to message #882810] Thu, 07 June 2012 08:51 Go to previous messageGo to next message
Thanks Dani,
But in that case; again i have to go to wizard to import that preference file. Is there any way to import that file without wizard ??
Re: Config file of CVS Repository [message #883094 is a reply to message #882903] Thu, 07 June 2012 16:53 Go to previous messageGo to next message
On 07.06.2012 14:51, Arpit Tripathi wrote:
> Thanks Dani,
> preference file.
Said who?
Dani
Re: Config file of CVS Repository [message #883248 is a reply to message #882903] Fri, 08 June 2012 02:17 Go to previous message
Thomas Schindl is currently offline Thomas Schindl
You only export them to know which preference keys you should set.
Reread Dani's proposal! You should ship a pluginCustomization.ini file
with your App.
Tom
Am 07.06.12 14:51, schrieb Arpit Tripathi:
> Thanks Dani,
Previous Topic:Eclipse Jobs API using thread pools?
Next Topic:PDE build workspace location
Current Time: Wed May 22 11:29:05 EDT 2013
Powered by FUDForum. Page generated in 0.02139 seconds
